-   -   Last issue before first drive... (http://www.clubcobra.com/forums/era-speak-bob-putnam/93356-last-issue-before-first-drive.html)
iwantacobra427 12-01-2008 06:48 PM
Brake lights are not working. The relay works and I have power at the brake switch. When I powered the relay directly, the brake lights worked. I replaced the switch and still.. no brake lights. The only thing I can think of is that I'm not developing enough pressure at the switch to close the circuit. I spent a lot of time bleeding the brake lines. Any ideas?
cobred 12-01-2008 07:50 PM
Jump the wires at the switch together to bypass the switch.
iwantacobra427 12-01-2008 08:47 PM
I did that too.. The brake lights work.
strictlypersonl 12-02-2008 03:30 AM
Check that the balance bar angle is adjusted properly. If the angle is set incorrectly, the pedal might feel firm but one side will not develop pressure.
Balance Bar Adjustment
