Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Factory Five Racing
Like Tree3Likes
  • 2 Post By lnfletcher
  • 1 Post By jwehr
Old 04-21-2016, 01:28 PM
Registered User
Cobra Make, Engine: ffr mk3 roadster 4.6 dohc sc
Default mk3 spats
i am looking for cf spats for my mk3 roadster to no a val. any ideas?
Old 04-21-2016, 01:33 PM
lnfletcher's Avatar
How about Plastidip? Works great and peels off when you want to remove it!
These have been on for 2 years and they still look great!
Updates
Gaz64 and hauss like this.
Old 11-27-2019, 11:23 AM
Cobra Make, Engine: FFR Roadster
How did you do that? Sprayed on? It looks great.
rads42 likes this.
FFR4247K
Old 11-27-2019, 12:53 PM
lnfletcher's Avatar
Sprayed on and they peel off when you don't want them anymore!
The key is putting on at least 5 coats, if you don't they peel off in little bitty pieces.
It you put on 5 or more coats, it peels off in one really tough sheet of rubber!
Mask off the area and peel off the masking tape away from the area as soon as the last coat is sprayed.
Performix Plasti Dip from Lowes or other retailers.
Old 12-15-2019, 01:38 PM
toadster's Avatar
Cobra Make, Engine: FFR #9772
Send a message via ICQ to toadster
my son used plasti-dip on his mustang, I have to say, I was pretty impressed! It stayed on the car for 3 years, no chips, etc...
Build Details
25th Anniversary Mark IV | #20 of 25 | Build #9772
25th Anniversary FFR Registry
Old 12-16-2019, 06:30 AM
undy's Avatar
I don't know if you can still find a set of these somewhere but I bought these carbon fiber spats from F5 years ago for me Lonestar. With very minor trimming they fit perfectly. They attached with 3M double sided tape.
Too many toys?? never!
Old 12-16-2019, 09:48 AM
https://www.metrommp.com/images/Cata...-cat%20v14.pdf
Old 12-16-2019, 10:55 AM
hauss's Avatar
Default Great Idea
Updates
I only wish I had seen this one about a year and a half ago!
Old 12-18-2019, 07:38 AM
Does the plastidip run at all after it is sprayed or just do light multiple coats? The masking tape is removed right after the last coat?
Old 12-18-2019, 07:48 AM
lnfletcher's Avatar
It sort of melts into the previous coat. As long as you don't put it on way too heavy, it does not run. I tested it on a door that I was working on before spraying on my cobra, and I followed the instructions on the can and put five coats on. Right after spraying the last coat, I peeled off the tape pulling away from the paint.
When you peel it off, it's almost like the black Nitrile gloves.
Old 05-04-2020, 12:23 AM
lomdel's Avatar
Cobra Make, Engine: Backdraft RT3
I got hold of Rust-Oleum Peel Coat and tried the same thing. It works great, but the removing of the masking tape is where the problem is. It sometimes pulls the coating away. The trick is to pull it "flat" away from the coating and slowly. I succeeded on the third attempt!
Old 05-04-2020, 07:28 AM
1985 CCX's Avatar
Billy Andrews in NY has the snap on style, years ago when I purchased they were like $125 w/hardware for the pair
