Parts needed to complete
I am looking to buy a FFR Roadster. Do any of you have a complete list of parts needed to complete their kit from their assembly manual? I am going to go with their Pin drive irs, 17 inch wheels, 4 speed toploader, and all aluminum 427 FE. I would like to do a non doner build
Since your going carb'd(they supply you with a wiring harness), and the non donor route, your going to need to purchase the following parts:
CLUTCH CABLE ACCELERATOR CABLE TRANSMISSION MOUNT W/BOLTS DRIVESHAFT AND 4 ORIGINAL BOLTS SPEEDOMETER CABLE CIRCLIP, CLUTCH CABLE RETAINER MOTOR MOUNTS, RUBBER BUSHING, REAR EXHAUST HANGER UPPER RADIATOR HOSE, RADIATOR W/CAP LOWER RADIATOR HOSE FAN SHROUD W/OVERFLOW TANK MOUNTED FUEL TANK W/CAP AND MOUNT STRAPS, EMERGENCY BRAKE HANDLE, CABLES, W/HARDWARE BRAKE ASSEMBLY, SPINDLES, FRONT CONTROL ARMS, REAR UPPER W/BOLTS/NUTS CONTROL ARMS, REAR LOWER W/BOLTS/NUTS REAR AXLE ASSEMBLY, COMPLETE, A-ARMS, FRONT LOWER, UPPER STEERING COLUMN, W/IGNITION, TURN SIGNAL STALK, NON-TILT ONLY STEERING RACK W/TIE RODS, ENDS, BOOTS, NUTS, MOUNT BUSHINGS STEERING SHAFT ASSEMBLY, W/LOWER U JOINT, OEM NUTS/BOLTS, HORNS IGNITION CYLINDER WITH KEY VACUUM RESERVOIR, CYLINDER SHAPED, BLACK PLASTIC GROUND STRAP, BATTERY CABLE WITH TERMINAL, PEDAL BOX, BRAKE CLIP AND (2) PLASTIC WASHERS, ACCELERATOR PEDAL Bill S. |
Thanks Bill. I shoudove mentioned I was going the non doner route in the first thread I posted. Anyway, thanks again!:D
| All times are GMT -7. The time now is 03:46 PM. |
