Old 11-28-2009, 04:59 PM
dlampe's Avatar
Default I need a weber intake for an FE, anyone?
I was wondering if any of you tortured souls that have tried Weber's and went back to a four barrel have you old intake lying around. I am building an FE and I already have the Weber's but I need the intake with the canted mounts. If anyone can help, that would be great. I think I can get a new one from Pierce Manifold but I thought I would ask here first.
also, I lurk on the FE forum but I am no longer a member there. Would someone post the parts request for me on the other forum?
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 11-28-2009, 05:57 PM
Gunner's Avatar
Maybe we should all chip in on a Weber setup and just pass it around so that everyone can get it out of their system.
I admit I've been looking at a Weber setup, and other than the major kewllll factor, I can't imagine why.
Old 11-28-2009, 06:11 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Posted on FEForum
Dean
I posted a note in the classifieds, looking for a Weber Manifold. Will pass any responses your way
Paul Proefrock
www.65shlb.com
www.prdcrrct.com
Old 11-28-2009, 06:36 PM
dlampe's Avatar
Thanks Paul.
Old 11-28-2009, 06:50 PM
*13*'s Avatar
Why? Because you can! If I had a BB in a go-kart I wouldn't want to spend the money on Webers either. I did it for the wow factor but would do it again for the performance difference it made in the SBF.
ERA FIA 2088
Old 11-29-2009, 05:05 AM
FWIW - - Its a normally available Blue Thunder part...
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 11-29-2009, 11:50 AM
Jac Mac's Avatar
If the FE is going in that SPF40 Dean it needs either one or two Holleys to 'look' original.
Jac Mac
Old 11-29-2009, 12:05 PM
dlampe's Avatar
No, this Fe is for a future cobra project. I wish I had the webers on the SPF MK1 but the 4 barral runs to good to change.
Old 11-29-2009, 12:33 PM
Gunner's Avatar
On Weber manifolds, there seems to be an option for straight or angled (10*?) distributor bore. I can't figure out what that refers to... somebody 'splain?
Old 11-29-2009, 12:49 PM
Rick Parker's Avatar
The 10 degree option refers to the machining of the Carburetor mounting pads to allow them to tilt in towards engine centerline creating a lower profile for hood closure. It has nothing to do with fitament of the distributor, other than the overall being aware of the diameter.
Old 11-29-2009, 01:00 PM
WildBill3's Avatar
Wow this sounds like another coooool Lampe ride.
I agree Life is way to short to worry about gas milage.Other rides Crewcab Super Duty F350 Ford,Shlby Charger,66Mustang/Frankinstang,Chevy Van,KTM Dualsport,FFR Daytona Coupe SOLD... RUN N GUN 06,07,08,09 Hallet 09,
Old 11-29-2009, 09:15 PM
Gunner's Avatar
Originally Posted by Rick Parker View Post
The 10 degree option refers to the machining of the Carburetor mounting pads to allow them to tilt in towards engine centerline...
Thanks. I knew this was an option and understand it, but somewhere (I can't find it now) the reference was to a "10* Distributor Port Mill" which makes no sense at all. I'll see if I come across it again.
Old 12-04-2009, 05:11 PM
SoTxButler's Avatar
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Check out www.swartzracingmanifolds.com. They have an FE tab under products. The manifold for the high rise heads is mine. Paul has nice stuff.
Russ
Old 12-04-2009, 06:03 PM
dlampe's Avatar
That is some beautiful stuff!
Old 12-04-2009, 06:20 PM
*13*'s Avatar
Check out that Puke Tank! Would be nice to have the tools to build stuff like that!!!
ERA FIA 2088
