-   -   I need a weber intake for an FE, anyone? (http://www.clubcobra.com/forums/fe-talk/101152-i-need-weber-intake-fe-anyone.html)
dlampe 11-28-2009 03:59 PM
I was wondering if any of you tortured souls that have tried Weber's and went back to a four barrel have you old intake lying around. I am building an FE and I already have the Weber's but I need the intake with the canted mounts. If anyone can help, that would be great. I think I can get a new one from Pierce Manifold but I thought I would ask here first.
also, I lurk on the FE forum but I am no longer a member there. Would someone post the parts request for me on the other forum?
Gunner 11-28-2009 04:57 PM
Maybe we should all chip in on a Weber setup and just pass it around so that everyone can get it out of their system. :D
I admit I've been looking at a Weber setup, and other than the major kewllll factor, I can't imagine why.
PaulProe 11-28-2009 05:11 PM
Posted on FEForum
Dean
I posted a note in the classifieds, looking for a Weber Manifold. Will pass any responses your way
Paul Proefrock
dlampe 11-28-2009 05:36 PM
Thanks Paul.
*13* 11-28-2009 05:50 PM
Why? Because you can! :p If I had a BB in a go-kart I wouldn't want to spend the money on Webers either. I did it for the wow factor but would do it again for the performance difference it made in the SBF.
Barry_R 11-29-2009 04:05 AM
FWIW - - Its a normally available Blue Thunder part...
Jac Mac 11-29-2009 10:50 AM
If the FE is going in that SPF40 Dean it needs either one or two Holleys to 'look' original.:)
dlampe 11-29-2009 11:05 AM
No, this Fe is for a future cobra project. I wish I had the webers on the SPF MK1 but the 4 barral runs to good to change.
Gunner 11-29-2009 11:33 AM
On Weber manifolds, there seems to be an option for straight or angled (10*?) distributor bore. I can't figure out what that refers to... somebody 'splain?
Rick Parker 11-29-2009 11:49 AM
The 10 degree option refers to the machining of the Carburetor mounting pads to allow them to tilt in towards engine centerline creating a lower profile for hood closure. It has nothing to do with fitament of the distributor, other than the overall being aware of the diameter.
WildBill3 11-29-2009 12:00 PM
Wow this sounds like another coooool Lampe ride.:)
Gunner 11-29-2009 08:15 PM
Originally Posted by Rick Parker (Post 1005140)
The 10 degree option refers to the machining of the Carburetor mounting pads to allow them to tilt in towards engine centerline...
Thanks. I knew this was an option and understand it, but somewhere (I can't find it now) the reference was to a "10* Distributor Port Mill" which makes no sense at all. I'll see if I come across it again.
SoTxButler 12-04-2009 04:11 PM
Check out www.swartzracingmanifolds.com. They have an FE tab under products. The manifold for the high rise heads is mine. Paul has nice stuff.
dlampe 12-04-2009 05:03 PM
That is some beautiful stuff!
*13* 12-04-2009 05:20 PM
Check out that Puke Tank! Would be nice to have the tools to build stuff like that!!!
http://www.swartzracingmanifolds.com/feproducts/fe4.jpg
