12-10-2009, 07:25 PM
KS
Cobra Make, Engine: jbl
Originally Posted by elmariachi
If you'd be so inclined, here is my Comp 294S, installed with 5* advance:
Adv Duration 294 int./294 exh.
@ 050 inch Lift 248 int./248 exh.
Lash 0.022 in.
.605 lift
Lobe center angle 110
Lobe separation 106
using 10.5-1 compression, with the cam straight up.
512 tq @ 5000/529 hp @ 6000, avg tq 444, avg hp 368
cam optimized for max avg. hp at 3 deg advance
511 tq @ 5000/521 hp @ 6000, avg tq 449, avg hp 369
both above with 8" idle vacuum
12-10-2009, 07:26 PM
I am at 9.8:1. Thanks.
12-10-2009, 07:38 PM
KS
from open exhaust to 3" inlet dual race muffler that flows 2000cfm total
512tq/510hp to 506tq/506hp
from open exhaust to 2" inlet dual race muffler that flows 900 cfm total
512tq/510hp to 463tq/462hp
from open exhaust to 1.5" inlet dual race muffler that flows 500 cfm total
512tq/510hp to 436tq/422hp
this i find very interesting.
12-10-2009, 07:39 PM
KS
no problem, i just wagged the compression.
12-10-2009, 07:59 PM
A couple of years ago we had a nice thread on "Dyno Games" and tricks that can be used when putting an engine, or car, on a dyno to get higher numbers. We also had a discussion, and at least one of the better known engine builders participated, on the validity of advertised HP numbers. In response to my question on why the engine dynos are done with open headers (when nobody around here runs open headers and the exhaust sucks a huge amount of power off) he truthfully answered "because everybody else dynos that way and if I put an exhaust on there my engines won't appear competitive" -- or something like that. IMO, a "truthful dyno" run is done with the exhaust bolted on and the water pump pumping.
12-11-2009, 07:48 AM
Stolen Avitar
GA
Patrick, the question then becomes; Who's water pump? or What exhaust system? Is there a standard? Seems to me that this would open a big ol' can o' worms for no real reason.
Steve
12-11-2009, 07:54 AM
Steve
That's a valid point. BUT, having studied the posts on this forum for over a half dozen years, I would venture to say that more purchasers of engines believe their dyno sheet numbers than understand that those are not the numbers that are really powering their cars. You understand that, I understand that, but most people on this forum don't. Frankly, I would be happy if engine builders just had a black box warning down at the bottom of their dyno sheets that said "this dyno was done with open headers and blah blah blah, you can expect up to a ___% power loss or more when these items are attached to your engine."
12-11-2009, 08:33 AM
Further Reading...
12-11-2009, 09:58 AM
OH
Originally Posted by Gunner
Needs mufflers, air cleaner, water pump and alternator to be an apples-to-apples sim. Fan, too, for 60s tech. (When did electric fans become common?)
Actually, earlier in the '60's, the engines were tested without alternator, mufflers, etc., to get the most HP from the engine, as it was an advertising thing to sell more cars, advertise your car with the most HP. Often, the HP was overrated, like in my 1965 442, which was rated 345 HP, and more likely about 300 hp or so. In the late '60's, some engines were intentionally underrated for various reasons, the L88 vette, @ 430 HP (actual 550 HP) so more average people would buy the less expensive 427-435 HP for less money. The 428 CJ was rated 335 HP (more like 400-425 HP), less than the 428 PI (360 HP) , maybe for insurance, maybe for drag racing class assignment. The 426 hemi was rated 425 HP despite changes over the 6 years of passenger car production.
