-   -   427 s/oiler ? (http://www.clubcobra.com/forums/fe-talk/110526-427-s-oiler.html)
otto 05-08-2011 04:46 PM
427 s/oiler ?
Hi, been a while since i worked on one of these , is it possible to run a hyd. camshaft flat tappet or roller in a ford side oiler block. I reading somewhere that it said no but i thought with machining it could be done
thanks inadvance Bob
Barry_R 05-08-2011 06:32 PM
Depends. Some side oilers were machined for lifter oiling, while others were not. Blocks from 1968 on - production or service - are generally going to have the oiling passages drilled for hydraulics. Earlier production blocks are most likely undrilled. They can be converted but it ain't no fun job...
Excaliber 05-08-2011 09:02 PM
I choose to run a flat tappet even though I COULD run a hydraulic in my side oiler block. Which is a 1968 block.
