-   -   Motorcraft TA-31 Sealant (http://www.clubcobra.com/forums/fe-talk/112922-motorcraft-ta-31-sealant.html)
Archrms 10-14-2011 06:36 AM
I have to replace my intake gasket, and have seen the Motorcraft TA-31 Silicone Sealant recommended for this procedure in numerous threads. I have tried all of my local parts stores with no luck. They claim it is a Ford product, and therefore they do not sell it. Any idea where I can find this product?
ERA Chas 10-14-2011 06:44 AM
Buy it from Barry R. or the Ford dealer.
FWB 10-14-2011 07:12 AM
any ford dealer worth their snot will have it in stock,
FWB 10-14-2011 07:20 AM
you can buy online from ford.....
here's the Motorcraft web site
Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com
19.88 plus shipping, you will need a caulking gun to use it.
Fred
Archrms 10-14-2011 10:27 AM
Thanks for the link. Didn't know if the dealer would sell directly to the public, I know they can be funny about certain things.
FWB 10-14-2011 11:39 AM
dealer? not selling to the public? WTF
walk into the parts dept and ask for the stuff,...its why they are there
mreid 10-14-2011 12:40 PM
$20 and a caulk gun? What's the problem with using Permatex for a fraction of the price?
Snakebit 10-14-2011 04:43 PM
Use Permatex Hylomar $9.95 for a tube. Use it around the ports and "The Right Stuff" for the front and rear seal inplace of the rubber seals.
Barry_R 10-14-2011 05:15 PM
Its not a problem. Its just that the TA-31 works a lot better.
Every Ford dealer should have it in stock - I buy it by the case.
When you consider how much you get its actually cheaper than buying those little tubes - the stuff keeps for a very long time if you reseal the open tube end.
B&D in Texas 10-14-2011 11:03 PM
Look for Aftermarket Motorcraft Distributor
Archrms,
I work for an Motorcraft Distributor and I sell it to all of my local Ford Dealers. It looks like P&G auto is the local Motorcraft distributor. They Supply alot of Hard parts to the Ford dealers. You should pay alot less there
Questions let me know
zrayr 10-16-2011 07:29 AM
I would recommend Hylomar as well. Have used it in many different applications, and it's never failed me yet.
And you might want to compare the Permatex Hi-temp silicone product with the "Right Stuff" for the end sealing duties. It's pretty tough.
Z.
philminotti 10-16-2011 02:56 PM
I use TA-31 for all my sealing,with one important exception. The TA-31 is more durable than any permatex, IMHO. It's also easy to work with. It spreads very nicely. It's much easier to remove than the Right Stuff. If you've pulled your intake as many times as I have, that's important. The exception I referred to is the intake front and rear ends. My experience with my victor intake, which has especially large gaps, was that the Right Stuff was superior.
zrayr 10-16-2011 03:22 PM
Originally Posted by philminotti (Post 1156751)
I use TA-31 for all my sealing,with one important exception. The TA-31 is more durable than any permatex......."
Hylomar is not like any other Permatex product. Actually it is just sold by Permatex under license in the USA. It was originally developed by Rolls-Royce Aerospace Division for sealing joints in jet turbine engines. . It holds up very well in sealing against oils, all types of fuel, hydraulic fluid, and, coolants. It never dries out.
But it's definitely not useful for sealing up the end gaps.
Z.
elmariachi 10-17-2011 09:03 AM
Originally Posted by zrayr (Post 1156755)
But it's definitely not useful for sealing up the end gaps.Z.
Please elaborate why its not suitable for this, too much build required?
Thanks.
zrayr 10-17-2011 09:21 AM
Thanks.
exactly. Hylomar is great for small metal to metal gap sealing or to help supplement a gasket to seal, but the "right stuff" product or permatex hi-temp silicone sealer (my favorite silicone sealant) will bead up to the height needed, whereas Hylomar won't.
Z.
