November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-12-2016, 11:50 PM
Registered User
Default 427 fe coolant leak internal engine
Good day
First time posting looking for info. Have a friend who bought a cobra kit car with a 427 fe engine about 6-8 months ago has only put 700 to 800 miles on it since then went to change the oil and coolant drained out then the oil and it was not mixed.I took a look and decided to replace the intake gaskets easy and cheapest place to start cleaned out engine ran with out coolant for a minute or so drain oil and replaced filter. had him put 50 miles on it and drained oil this time it was milky in color mixed oil/coolant ,drained block flushed oil system out psi tested for 24hrs with drain plug out and had water in drain pan.removed right valve cover and took a look at the intake coolant cross over with my inspection camera pass noticed coolant around #3 cyl intake valve lifter finally found the failed area.Were the lifter valley curves up to block deck right above the curved area 1/8in up it was bubbling pin holes in the block about a 1/2 in area in length.Now comes the question he does not have the funds to repair it correctly replacement block what if any are his options i thought about sealing it with rustolem or glyptal paint so he could drive it until he gets the funds for the block. any insight would be helpful.
Thanks John
Old 06-13-2016, 06:40 AM
Clois Harlan's Avatar
replace your head gaskets....
"Let's roll"
"Be part of Something Good
Old 06-13-2016, 04:39 PM
Bernica's Avatar
Senior CC Premier Member
Yup. What Clois said...
Start with new head and intake gaskets.
Old 06-13-2016, 05:40 PM
How in the hell do new intake or head gaskets keep pinholes in the BLOCK from leaking coolant?
Am I missing something here? Or did I read him wrong?
Jim
Old 06-13-2016, 05:57 PM
DanEC's Avatar
I kind of wondered about that too. I know blocks can be pinned and stitch welded. Not sure it's possible in that location. Also, pretty much involves a complete tear down of the engine. I think I might be tempted to throw a couple BARS tablets in it and see what happens.
ERA 782 Running
Old 06-13-2016, 06:38 PM
Bernica's Avatar
No, I missed something and read it wrong as well. Not sure how the pressure test was done, but doesn't sound like good news. Can't think of a reliable fix for something like this without a teardown. Assuming it is a cast iron block?
Old 06-14-2016, 03:58 AM
I would try some Moroso Ceramic Seal or some Bars Leak first.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
