November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree6Likes
Old 05-27-2019, 12:05 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
my 452 FE used to do this, as yes I just got used to letting out the clutch a little while other foot on the brake. Make sure your TOTAL timing is no more that 36 degrees. I did this and it seemed get better.
Old 05-27-2019, 01:54 PM
Cobra Make, Engine: Midstates 427 / ERA 289 USRRC
Do you by chance have an electric fan? If so, disconnect the fan and then start and stop the engine and see if that fixes your problem. Sometimes the fan still spinning on shutdown bleeds voltage over to the ignition and or MSD. If this is your problem, you can install a diode or relay on the electric fan and this will solve your issue.
ERA 626 likes this.
Old 05-28-2019, 02:25 AM
Gaz64's Avatar
That can only happen if not using relays for fan control.
Gary
Old 05-28-2019, 09:38 AM
Gary
That is correct. As mentioned in my earlier post, the solution is to either install a relay (if you don't already have one) or diode (if you don't want to use a relay) and that will solve the issue. The correct way (for several reasons) is to have your fan run through a relay.
Gaz64 likes this.
Rate This Thread:
