FE TALK
http://www.clubcobra.com/forums/fe-talk/)
Oil Pan Gasket
http://www.clubcobra.com/forums/fe-talk/141896-oil-pan-gasket.html)
| Kobura |
02-06-2019 11:45 AM |
I replaced my oil pan without using sealant because I had read that if you needed to remove it again, the sealant could make the job more difficult. I mention this because I noted that you intend to use sealant for your repair.
| Large Arbor |
02-06-2019 12:21 PM |
Kobura,
If I did not use sealant I am sure it would leak like a stuck pig. The windage tray and the pan create the need for 2 gaskets. I do hear what your saying about getting it off. It took a carpenters knife to do it this time but it was manageable.
Phil
| All times are GMT -7. The time now is 04:26 PM. |
