-   -   pilot bearing for a 391 crank (http://www.clubcobra.com/forums/fe-talk/142473-pilot-bearing-391-crank.html)
cobrabritt83 06-17-2019 01:04 PM
Has anyone used a 391 truck crank in a 427 FE? I'm trying to find a pilot bearing that would work with a TKO 600.
blykins 06-17-2019 01:27 PM
Quite frequently.
I machine an adapter so you can use a regular FE bushing or bearing. Otherwise you can use a regular FT bushing.
Dwight 06-17-2019 07:53 PM
I swapped my top loader for a T-5 in my '66 Fairlane last week. I have a 390 motor. I bought a bronze bushing from O'Reilly's part store for $7.
I think the T-5 and TKO input shafts are the same size.
And a buddy of mine told me after the fact that roller bearings are available for the 390 crank.
Hammered in it and I have put over 300 miles on the car this weekend with no problems
blykins 06-18-2019 01:30 AM
The 391 crank is a different animal and doesn’t take normal FE bushings.
Mark IV 06-18-2019 02:25 AM
Not to mention the crank nose diameter that will need to be addressed if an FE damper is used.
Dwight 06-18-2019 05:55 AM
My buddy found three 391 motor / blocks locally last week. He is looking to use one for a motor in his '66 F100.
blykins can he use the 391 block and a 390 crank?
blykins 06-18-2019 07:48 AM
Yes, but FT blocks need to be bushed for the different sized distributor shaft.
Dwight 06-18-2019 06:01 PM
Thanks
we knew about the bushing for the distributor
