FE TALK
http://www.clubcobra.com/forums/fe-talk/)
FE engine builders
http://www.clubcobra.com/forums/fe-talk/145781-fe-engine-builders.html)
| cobragene |
03-27-2022 05:26 PM |
FE engine builders
I have a 428 bored .030 with performer heads 6006 from late 1990s, when the engine was completed comp ratio came in at 9.9-1 later I had an issue and the heads cut .004 . The head Literature says chambers are 72CC and each .005 cut reduces chamber volume by 1CC. Can anyone (Brent) tell me what comp. Would now be? Thank you
| Unique427 |
03-27-2022 06:21 PM |
| blykins |
03-28-2022 10:44 AM |
If it was exactly 9.9:1 before and you don't had heads cut .004" then you approximately knocked off a cc, which would raise your compression ratio about .1 of a point. So you're still at around 10:1.
| cobragene |
03-28-2022 06:47 PM |
Thanks guys
| All times are GMT -7. The time now is 06:28 AM. |
