C6ME Block
Looking at a 428 Block with c6me code. The seller claims it's from a Police Interceptor or Ford Galaxie. Is this any other questions or markings I can find out about to see if it is a "true" PI block.
TIA. |
Ford References say:
C6ME-A 1966 428 428-4v, Police Interceptor |
pull the pan....
and see if it has the reinforced webbing,
then measure the rod bolts. PI's have 13/32 diameter bolts. What about the factory aluminum intake, is it on there ???? Good luck, Bill Cook :D |
I will check it out.
Thanks. Not sure what info I can get as it long distance and I will not be able to drive. Also, it's a standard bore block. Are there any other code type indicators I can ask about? |
That's the only ways I know of to check the block.
You can't trust the fifth digit (P) of the car, engines got changed all of the time. Great to hear it's STD. Cheers, BC :D |
| All times are GMT -7. The time now is 10:54 AM. |
