FE TALK
http://www.clubcobra.com/forums/fe-talk/)
| SUPERGONZO |
10-15-2003 08:22 PM |
428 cobra jet mustang exhaust
Has anyone tried to enlarge a set of stock 428 CJ 68' mustang exhausts? The stock size is 2 1/4". I would like to get 2 1/2" on there with a x-pipe.
Are there any better exhaust that will fit a 68 428CJ without going to headers??
| FFR428 |
10-18-2003 07:11 AM |
you might check the 428 cobrajet registry for an answer. Also the Ford FE forum if no one can help you here. Good luck, G.
| SUPERGONZO |
10-20-2003 03:36 PM |
haven't gotten any response there either
| ed cougar |
10-20-2003 04:33 PM |
428 exhaust manifold
You can have them extruded if you have the $$ not sure how much it cost nor where to have it done only heard about it from shop talk. For what it's worth they have an extrusion process whitch pumps a heavy grit claylike substance through the manifold under hydraulic pressure whitch removes material as it smooths the insides to a polished finish, maybe someone more knowledgable on the process can elaborate. I used a dremmel on my cj manifolds and tried to smooth them up inside but I grew impatient and gave up on it.
| All times are GMT -7. The time now is 09:29 PM. |
