Old 04-17-2004, 10:50 PM
Cobra75's Avatar
Cobra Make, Engine: CSX 4100-Shelby 75th Anniversary Edition
Send a message via AIM to Cobra75
Default Starters for Shelby FE alum block
I need to replace my starter. Any recommendations that will work for an aluminum Shelby block? Will a Powermaster, Tilton and Prostart'r all fit the aluminum block? I know there are some clearance issues with the boss for the screw-in core plugs.
If there was a thread that addressed this already, can you give me the link?
Scott Harrison
CSX4100
Growing old is mandatory...growing up is optional.
Old 04-20-2004, 09:47 PM
Cobra Make, Engine: 76 F250, 511ci Shelby Aluminum block, LAE billet crank, Oliver billet rods, Arias pistons, Keith Craft CNC Edelbrock heads, Custom Roller, Titanium valves, Erson Rockers, Victor, Dominator
Unfortunately, the only one I know fits without issues is the Tilton, which is what Shelby sells. I just spoke to a Gentleman who said he used a Powermaster on his Shelby block, but it required modification.
I don't know about the others.
-Scouder
Can't have a Cobra 'til I buy my wife an Excursion.
Old 04-20-2004, 10:57 PM
Cobra75's Avatar
Thanks for the info. I just installed a CVR Protorque. Model 5049M. It installs with no modifications, and has 18 positions for clearing the block, headers or oil pan.
Scott Harrison
CSX4100
Old 04-21-2004, 05:43 PM
RedCSX1's Avatar
Great Question. Scott, Where did you purchase the starter? How do you like it so far? I will be needing one for the 63 center oiler I just built if my CSX Cobra ever gets here!
Morgan
Morgan LeBlanc
Fresno CA
Old 04-21-2004, 10:07 PM
Cobra75's Avatar
I got a CVR Protorque No. 5049m from George Anderson at Guessford Machine.http://www.gessford.com/cobraparts/fmisc.htm
I had an incorrect starter for 5 years and kept replacing pinion gears. After speaking with George for 10 minutes, he fixed me up with just what I needed and overnighted it to me. He was professional, personable, and terrific to work with! I had previously called every local & national speed shop for an FE mini-starter, but no one had one in stock or could get it in less than 2 weeks. The starter nose plate required no modifications, fits the alum. block with the raised block & drain plug bosses, aviad oil pan and headers.
This starter is available in two versions, the 5049M is rated at 3 hp, the 5049 at 1.9 hp. About $50 difference in price. Someone said Jegs carries the 5049.
http://www.cvrproducts.com/main.html
Scott Harrison
CSX4100
Old 04-21-2004, 10:21 PM
The 5049M is much better than the cheaper 5049...don't get the 5049 for long life!
George
difference in dimensions 5049 and 5049M
Old 04-21-2004, 11:30 PM
ERA 626's Avatar
I used a tilton on mine and it works fine.
