Old 02-20-2006, 08:03 AM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Default FE Plug Wires?
Has anyone used the MSD plug wire kits that you finish off the distributor ends youself, and did you find that all the wires were long enough to rout correctly?
Old 02-20-2006, 08:52 AM
snakebit31's Avatar
Cobra Make, Engine: FFR#2296, 428FE, IRS(sold) FFR Daytona Coupe under construction
I posted a reply last night, however it did not appear today. As I had indicated, if you have not purchased the Universal wire kit, MSD has a kit for FE's. I bought mine from PAW, part number MSD-3138. They list it for a 390, and it was an 8mm wire.
I noticed you are in Grand Rapids. In the 70's while attending WMU, I was in the ski patrol at Cannonsburg.
Old 02-20-2006, 09:23 AM
Burgs's Avatar
Ah-ha,.. I did not know that, thanks! Did they rout correctly over the valve covers and clean to the distributor?
The ski hills have been hurting this winter. It is finally cold enough to make, and keep, snow, just in time for March to arrive.
Old 02-20-2006, 09:32 AM
Burgs's Avatar
One more thing,... what color are those?
Thanks!
Old 02-20-2006, 09:53 AM
snakebit31's Avatar
Here's a shot of mine, before cleaning up the engine bay.[IMG][/IMG]
Old 02-26-2006, 05:44 AM
427 S/O's Avatar
Burgs, I purchased the MSD kit, it's easy and clean looking, I don't care for the universal kits, they look universal.......
Perry
Old 02-26-2006, 08:09 PM
Burgs's Avatar
Hey Perry, were they plenty long enough to rout them correctly?
Old 02-27-2006, 03:44 PM
427 S/O's Avatar
Oh yeah, just measure carefully, they include everything you need.
Perry
Old 02-27-2006, 06:45 PM
Burgs's Avatar
Thanks for the help!
Old 02-27-2006, 08:50 PM
Specialk's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
I got the ready made wires from MSD. I have never had much luck making up universal sets, and the pre-made sets have the ends sealed on.
kris kincaid
Old 02-28-2006, 03:36 PM
427 S/O's Avatar
The plug ends are sealed from the factory, you only work the distributor ends.
Perry
Old 03-08-2006, 10:40 AM
Don McCain's Avatar
Cobra Make, Engine: Shelby CSX4870, Shelby 496
Thumbs up Wire Sets
BURGS-We will have a wire set available 4/15(approx) that is pre cut, boots on the dist. end and a HD boot on the spark plug end. Each wire is numbered for the cylinder
it goes on and all wires go over the valve covers. They fit all
FE engines from 332 to 428 CID. These will be std. equipment on all of our engines. Wires are 8MM and provide static free sound quality for your audio systems.
The wires feature our C/S Logo and Carroll's signature and best of all, they're MADE IN THE USA The wire sets will be marketed as Carroll Shelby Signature Series. More later.
Old 03-08-2006, 01:27 PM
Specialk's Avatar
Don, any idea how much they'll be? Do you work for Shelby?
kris kincaid
Old 07-21-2006, 04:46 PM
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
Don McCain: Can you provide more information on the above C/S ignition wire sets? How about a part number, etc?
Thank you, Bob
Old 07-21-2006, 05:56 PM
lineslinger's Avatar
Back on topic....yes Burgs, I did use that setup in my engine build because I wanted to detail the way the "loom" laid out. It is a fairly straight forward job with minimal hassles.
Old 07-21-2006, 07:51 PM
FUNFER2's Avatar
The universal kit is really easy to do, just takes time. I like the clean look.
Here's a photo of mine.
Kevin
Old 07-24-2006, 12:04 PM
Burgs's Avatar
Just as a follow up, they worked out great! The stock looms that clip onto the valve covers need to be opened up a bit, but worked out fine.
Thanks for the help,
Brad
Old 07-24-2006, 01:39 PM
I like your hood prop, can also be used as a hockey stick huh? Or did you just "borrow" it from one of your kids.
Old 07-25-2006, 10:32 AM
clayfoushee's Avatar
Cobra Make, Engine: Unique, 427SO, it runs
I used 9.5MM from Ford Racing and custom cut each length for proper routing. There was plenty of extra even on the longest run. Yes, it was a little anal, but it worked out nicely.
Clay
