Inexpensive forged FE stroker crank?
Using a 391 crank:
Offset grinding a 391 crank to BB Chevy bearing size could achieve a 4.256" stroke; by offset grinding only to a 4.250" stroke, you would assure a fully ground journal. Offset grinding may also remove enough metal so that little or no heavy metal is needed to internally balance the crank. The Chevy bearing is a bit wider, I don't know if that would weaken the crank? If this will work, I think it might be able to be done for no more, possibly less, than a Scat "Cast Steel" stroker. Obviously, I'm looking for comments on this idea. 390 = 3.78" stroke, 2.4384 inch rod journal diameter. BB Chevy=2.2" rod journal diameter. .238" difference (doubled)=4.256" stroke |
I think for the price of all the machine work you're gonna be in for, you could have a new Scat crank.
You're gonna have to turn down the snout, the flywheel flange, plus offset grind the rod journals....then turn the mains down. Added to that, 391 cranks are not cross drilled.....so that would be an added expense plus any polishing and chamfering you'd wanna do. I say go for the Scat. Keith Craft uses them on all his stroker engines. I have a new Scat 3.98 crank...and I have no worries... |
Yeah, seriously. You'd spend way more in machine work to that 391 crank than it would cost to buy a brand new Scat stroker crank.
Carnut,
Your math is off. To increase stroke, you must move the centroid of the rod journal down. So, when offset grinding, you would leave the bottom of the journal at its present location...cause you cant go any lower...and cut at the the top of the journal. The new journal centroid for the BBC journal would be at 1.1" from bottom. The original stock centroid was at 1.2192" from journal bottom. So, the new effective centroid moved .1192" down. Hence, your new stroke would be 3.78" + .1192" = 3.899" This is max stroke for this combo. However, some shops can weld more material to the bottom of each journal to increase stroke even further...but this is expensive...call Kieth Craft. I sold kieth all 4 of my 391 cranks...he machines them and sells them to racers who like to spin them at 7500 rpm. Forged steel units are great cranks, but for $500 bucks...you cant beat the cast iron scat cranks in 4.125 or 4.25" strokes. |
Keith doesn't put Scat cast cranks ($695) in all his stroker motors; those with the cash put in a billet ($2495), which is much stronger.
Steve, I'll definitely admit my math could be wrong, as this sort of thing gets pretty fuzzy for me. It still seems to me that you want to move the centroid of the journal up, not down, to increase stroke. However, I'll give it some more thought after the smoke stops coming out of my ears and possibly understand your explanation. As to the Scat crank, I've already got one in my 496. If money (and value) were no object, I'd have a billet stroker instead for the increased strength. I won't take my engine above 5700 with the cast crank, it's the weak link. I came up with this possible idea in my quest for a forged crank, much stronger than a cast one, and cheaper than a billet. Thanks to all, Dan |
Dan :JEKYLHYDE |
The difference in the BBChevy journal which is 2.200 and the FE Ford journal which is 2.438 is .238 so with the 391 truck crank having a stroke of 3.784 you can stroke it .238 thousands with a perfect crank. We will stroke most of them to 4.000. You could possible get 4.020 stroke with everything just right. We do these for some race applications where you can not run more stroke than this or if a customer wants a steel crank but does not want to spend 2400.00. You have to remember they are about 35 years old and were used in heavy trucks so they had a pretty rough life. I have made up to 800HP with these cranks but have also had some cracked when we freshened the engine and wet magged the crankshaft which we do on all of our engines. You will spend at least 800.00 easy doing one of these cranks right if you have the core. You have to turn down the nose and re key it, machine the back of the crank for a spacer to bring back to the right size for converter or regular transmission pilot bearing. Of set grind the crankshaft and either widen the rod throw by side grinding into the counter weights which is quite expensive or narrow the rods and leave the crankshaft the stock width and narrow the rods and rod bearings. This is not the ideal project for the regular guy trying to save money. The Scat cast steel cranks arwe good for up to about 750HP. I have had some out there for about 2 years that are making between 700 and 7550 with them and no problems. I do use a lot of billet crankshafts for some of the higher end engines that will make a lot of power or for customers that just want a billet. Make sure the other parts that you have will handle 700HP before you worry to much about the crankshaft. Hope this helps and good luck, Keith
Thanks for the info, Keith. I give myself an 'A' for effort even though my math was wrong (never my best subject). At the least, this post shows an interest in a forged stroker. As for my Scat cast crank, I don't want to be the one to find out they all won't take that much hp. It's not just the hp, it's also the RPMs with that long stroke, as the piston speed gets to the point where you want premium parts to keep it together past 5500-6000 RPM, and I don't consider the cast cranks a premium part, just something to get me by until a forged unit comes along. Call me cautious, I've blown a motor before and don't care to repeat the experience.
THANKS, Dan |
Dan,math is one of my best subjects...scary huh!
Still learning about these engines, though. Thanks for the info...I reworked this on paper and I concurr... Keith, Thanks for the info as well. |
Cross-drilling is a waste (just my opinion) and actually a potential trouble-spot. Nothing wrong with cast iron cranks. 391 cranks ARE nice, because they're steel and NOT cross-drilled. If you need all that. Most can get along with a cast crank. |
This now becomes a thread about spectacular crank failures and the situations that brought them on. Let's hear the stories... |
Scat Cast steel cranks
Time will tell on these cranks but I have not had any problems in the 3 years that we have been using them. I do have some in FE engines that the guys are turning 7000rpms. I will let you know how it works out because i just put one in my 482C.I. Shelby block engine for my Kirkham that has a mild solid street roller with our stage 3 heads and Victor intake. I also installed a throttle body direct port fuel injection system to test as well. This engine made 642 ft/lbs torque at 4600 rpms and 700HP at 6800 rpms. We made about 20 dyno pulls on it tuning the Fast system for best results. I will also be testing on the chassi dyno as well. I will let everyone know how this works out. If I do not sell the car before then I will probably take this package to run and gun but everything I have is for sale. I have run quite a few of the Scat 460 stroker cranks in the 460 engines now for about 6 years and made up to 850HP with them and about 6800 to 7000rpms with no problems.
We do use a lot of the Scat billet cranks for anyone that can afford and want to go that route. Thanks, Keith |
If I had your money I'd rap it up too, Keith. :LOL: Good luck on your latest build. I thought you already had one, remember reading about you having it on the dyno, and you had a billet crank in it. Shelly said it rattled the whole shop when you had it on the dyno. I guess it got sold... Dan |
Cranks
I did a 527C.I. FE engine that I did take to Run and Gun last year with the billet crankshaft and 2X4s that made about 750HP. It was a little wild but very drivable. I had a customer in CA that wanted the car and I sold it to him. I have another Kirkham going together with the new 482C.I. engine and it only made 702HP but I think that will do. I wanted to do some testing on the fuel injection and learn more about the Fast system and doing some tuning while driving down the road. Good luck, Keith Craft
I am going to build my 427 s.o., but I do not have the steel crank for it. I have several of the iron 390 cranks and a couple of the steel 391 cranks. Wouldn't the 391 steel be better (non stroked) for this engine? Yes, I would need to have machine work done. Jim
The snout on the 391 crank is too big but can be turned down. The rear flange also must be machined. Also, it will need 'heavy metal' added to it to get it balanced. They are generally not worth the expense, but if that's what you want, go for it.
I have two 505 FEs. One currently at 712HP, the other at 752HP. Both have the Scat cast 4.25 cranks in them. Both are limited to 6500RPM because thats where the power ended. The weaker one has been in my car and on the dyno repeatedly - perhaps 50 pulls and at least that many 10 sec 1/4 mile passes. The stronger one was my Engine Masters deal, and has been just a dyno queen (a few dozen pulls) - - it'll go in the car this summer. So far neither shows any sign of crank distress (fingers crossed).
Barry R. Survival Motorsports |
Thanks for the reply Barry R., but for now I'll stick to my 5500. Perhaps as time goes by I'll be more adventurous with it.
Dan |
| All times are GMT -7. The time now is 08:45 AM. |
