November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-01-2006, 08:23 PM
Default wiring mess
Well i tried to wire in a pushbutton momentary switch and a regular switch to cut all power to the acc. side of the key switch. Did away with key switch. Any one else do this. If so , can you explain how you did it. Im at wit ends on this mess. Thanks
Old 04-02-2006, 08:52 AM
Please explain exactly what you want.
Do you want a single master switch for all power, and a pushbutton starter switch?
Do you want the starter switch to function whether the master switch is on or not?
Do you want the ignition circuit separate from the other accessories?
Old 04-02-2006, 10:28 AM
Well I have the pushbutton on seperate power and its ok. Now I would like to kill the power to anything after the switch---all acc. and the ignition. I also have a msd ignition, not sure but i think it picks power up from somewhere else. The power was going to the the battery terminal on the ignition switch. Then acc. on one side,and ign. on the third side . The center was for the starter.
I would like to kill all voltage after the toggle switch is tured off, including ignition. I think there 25 to 27amps with all loads on. Checked them in line with a meter.the meter only goes to 10 amp dc.I checked them seperate, one at a time. Could i put a 40 amp dc relay in line so the switch would be ok.
thanks
Old 04-11-2006, 09:53 AM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
I have a Mallory battery kill switch in my trunk next to the battery (std. contemporary location). I have an ignition switch which pulls power off the fuse block (hot all the time) and my MSD runs off two locations on the starter selinoid. I did this because the starter selinoid is fed directly by OO gauge battery cable and the positive side of the starter selinoid (key on) is an easy place to access if the MSD needs to be changed.
I'm a little unclear on why you want to kill power AFTER the switch. Is the momentary switch for the starter? This would make sense and be correct for an english car, AC, MG Austin, Triumph, etc.
It is likely the key switch powers several circuts including the starter selinoid which may in turn power others (not uncommon). Why do you want to kill power after the switch? It makes more sense to kill power before the switch.
You might consider shutting all power off with something like this...
http://www.magnumforce.com/flaming_r...y_switches.asp
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 04-11-2006, 10:01 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
You can use a NC ( Normally closed ) 12V DC relay and pass the Acc. through the contacts. The push button can be used to activate the relay and interrupt the NO contacts.
Why, I do not follow, but here is the answer to your question.
Hope this helps.
