Rich Idle
What are some ways to lean out my idle. It is a bit rough on the eye's when idling most likely due to my cam and 850 Holley.
Thank Mike......... Crower Cam INTAKE: Duration: 310º Lift: 0.598 EXHAUST: Duration: 320º Lift: 0.614 LOBE SEPERATION 110º Duration at .050" Intake: 254 Exhaust: 266 LOBE LIFT Intake: 0.34 Exhaust: 0.349 |
1) Adjust the idle mixture screws.
2) Make sure that the power valve is NOT opening at idle. |
Mike
You can insert a piece of Safety wire in the Idle circuit and it will reduce the amount of fuel and richness on idle..... Morris |
| All times are GMT -7. The time now is 11:38 AM. |
