-   -   Aviad Oil Pan Capacity - Follow Up Question (http://www.clubcobra.com/forums/fe-talk/78913-aviad-oil-pan-capacity-follow-up-question.html)
rsimoes 05-13-2007 07:42 PM
I found this post:
http://www.clubcobra.com/forums/show...l+pan+capacity
But the problem is that my oil pan was filled with 11 quarts and the dip stick marked at full. (after the engine was primed and run)
I saw the instructions on how to mark the high and low before the engine was run. But now that it has been run, how should I mark the high and low on the new dipstick I got?
Thanks!
Anthony 05-13-2007 09:18 PM
Thanks!
Drain the pan, then fill it with 8 qts, and mark the stick as low. Then add another qt and mark the stick as full.
rsimoes 05-14-2007 05:43 AM
I guess that makes sense. . .
Maybe I'll let it drain overnight and then put in 8 quarts into the engine, wait a while for it to all get into the pan, then mark it and add one quart, wait a while and mark it. Then run it, let it sit and check the level . .. and if I change the filter too, fill the filter with oil, then run it and check the level. . .
sound about right?
So for each oil change, I'll only change about 9 or 10 quarts (with filter) is that about right too?
Rick Parker 05-14-2007 08:22 AM
Yes unless you make a point of attempting to purposly remove the oil from oil cooler and lines. (unnecessary)
