-   -   edelbrock fe cyl head thread size? (http://www.clubcobra.com/forums/fe-talk/84031-edelbrock-fe-cyl-head-thread-size.html)
wrench87 11-23-2007 07:57 PM
does any one know the depth and thread size of the valve cover bolt hole on a edelbrock aluminum fe cyl head?. i want to use stainless steel studs but i dont have my heads yet.
PaulProe 11-23-2007 08:03 PM
Stud Size
The FE is probably the only engine in the world that doesn't use 1/4" screws.
The threads are 5/16-18. Depth varies but typically is 3/4"
The bosses on your valve covers will determine what length is needed. I ended up buying Stainless Steel set screws from McMaster Carr to make mine
Paul
wrench87 11-24-2007 04:22 AM
paul i am running the ford motorsport aluminum cobra lemans valve covers i forgot about the gasket also i am thinking i need 1 1/2 inches what length did you use for you valve covers?
PaulProe 11-24-2007 06:57 PM
Stud size
I used the Ford Motorsports cast covers also, with cork cover gaskets. I also included an "AN" cadmium plated washer and a flanged nut.
I used 5/16-18 x 1 3/4" stainless steel set screw. All the materials came from McMaster-Carr
Paul
