  #101 (permalink)
Old 10-07-2009, 06:21 PM
ZOERA-SC7XX's Avatar
I didn't realize ERA is the only Cobra that has free open access to the oil pan. it just drops straight down with no interference. Nothing in the way. Worth the price of admission in itself.
  #102 (permalink)
Old 10-07-2009, 06:25 PM
Yep, here's a shot for the po' folk that spent their money on CSX, Kirkham, SPF, and like stuff....
  #103 (permalink)
Old 10-07-2009, 07:37 PM
dcdoug's Avatar
Here's my take. I don't think the one broken bolt is causing your leak. As I wrote the other day, I have the same Canton pan and it leaked down the side rails/flanges at rpm above 2000 or so. The flanges were not straight. After putting a straight edge (square) to it I saw the non-flat condition of the pan. The pan came like this from the factory. Just do some tweaking and hammer the holes down so the straight edge shows no more than .020 gap. Plug up the hole from the broken bolt with silicone. I've had broken pan bolts before without leakage. Pulling the engine for one broken bolt shouldn't be necessary.
Pat's right. I just couldn't bring myself to do that, but I might be saner if I did. I will double check the flanges side-to-side as well as down the length of the pan (which is what I checked before) to be sure they are flat and if not adjust them.
www.partskeeper.com
  #104 (permalink)
Old 10-07-2009, 07:53 PM
dcdoug's Avatar
OK, here are some pics of the hole and it's location. Corner bolt, rear of the pan. I checked the hole again tonight and while the sides look pretty bad (from removing the broken extractor which I couldn't drill completely straight on), the "top" and "bottom" at least in this perspective should still have good thread as there is still a thin layer of the broken bolt against those threads.
My plan is to drill out this hole with a 1/4" bit which fits perfectly into the other pan bolt holes and then see what I have to work with. I still think there is an outside chance I can clean the threads up with a tap and use the Permatex solution to rebuild the damaged/missing threads. If not, then I already have a great pilot hole for the TimeSert.
I did order today a set of tap sockets (wish I knew these existed a week ago - TimeSert site suggested them) and a tap guide which should help a lot with keeping the tap plumb.
I will ultimately have to use a bit of extra silicon around this bolt hole to fill the small gaps that remain on the side of the bolt hole.
www.partskeeper.com
  #105 (permalink)
Old 10-07-2009, 08:14 PM
Cobra Make, Engine: Contemporary Classics 427 SC, 427 sideoiler
Happily, the Contemporary has a clean shot at the pan also. It really reduces the PITA factor.
  #106 (permalink)
Old 10-07-2009, 09:08 PM
Doug it looks like you are making progress, though it couldn't have happened in a worse hole.
The Hurricane is free of any obstructions well, the pan can drop straight down.
  #107 (permalink)
Old 10-08-2009, 04:35 AM
OK, I must be really dumb this morning, but in the picture below, what is the hex nut looking thing and what is the big crater just above and to the right of it?
  #108 (permalink)
Old 10-08-2009, 04:57 AM
dcdoug's Avatar
Not sure about the hex nut. Some sort of plug? It is outside the pan rail. The "crater" is the bolt hole. The "cratered" piece of it is mostly near the surface and the hole is normal further down. It looks like it is really large and blown out in this photo, but you still can't stick a 1/4 bit down the center of it, so there is still some bolt left along the sides. So when drilled out, it should clean up reasonably well. As mentioned before, the damage on the sides came from getting the extractor out, but isn't that deep. The out-of-round pieces along the sides should fill reasonable well with either epoxy if I can do the Permatex solution or silicone if I end up with the TermSert.
www.partskeeper.com
  #109 (permalink)
Old 10-08-2009, 06:34 AM
That makes sense now. I was looking at that hex plug thinking that was the end of the bolt that had broken off and now you had magically partially drilled it out a bit in the shape of a hex pattern.
  #110 (permalink)
Old 10-08-2009, 06:42 AM
X 2.
I feel more strongly after seeing it-either TimeSert it or oversize it and stud it as I said before. Either way, I'd rather not remove/install that fastener more than once.
Me-I'd stud it oversize.
Chas.
  #111 (permalink)
Old 10-08-2009, 06:57 AM
dcdoug's Avatar
More coffee before Club Cobra.....
www.partskeeper.com
  #112 (permalink)
Old 10-08-2009, 06:59 AM
dcdoug's Avatar
X 2.
I ordered a timesert kit and will likely end up that route unless the hole looks pretty good when I drill it out. I also ordered a tap guide and tap sockets which should allow me to get it plumb. Will be a fun weekend......but at least I should make some progress.
www.partskeeper.com
  #113 (permalink)
Old 10-08-2009, 07:19 AM
Good Doug.
Just be careful to not break through the boss on the inside of the block. They aren't really generous.
Chas.
  #114 (permalink)
Old 10-08-2009, 07:24 AM
dcdoug's Avatar
Good Doug.
Good to know. I will wrap electrical tape around the bit so I know that I haven't gone too far.
www.partskeeper.com
  #115 (permalink)
Old 10-08-2009, 07:35 AM
Good Doug.
Uhh, you know that if you do break the boss, it's a pretty big deal. Not like "windowing the block" or anything, but still a pretty big deal.
  #116 (permalink)
Old 10-08-2009, 07:38 AM
dcdoug's Avatar
That's what makes me a little nervous about the Timesert since it's a slightly oversize hole. On the drilling, I will be checking the depth measurements repeatedly plus taping off the bit at the right depth. Other suggestions?
www.partskeeper.com
  #117 (permalink)
Old 10-08-2009, 07:41 AM
The only other thing I could think of would be a portable drill guide. That would help you have a nice straight hole but I just don't know if you could use one of them down under there. This is what they look like, but I just don't think you could use it:
  #118 (permalink)
Old 10-08-2009, 07:56 AM
dcdoug's Avatar
I don't think i have room for that. I did get a hand guide for the tap and I was planning to use for the drill too. Not as good as above, but will fit in the space I have.
www.partskeeper.com
  #119 (permalink)
Old 10-08-2009, 07:58 AM
Then go for it. If you screw something up, we'll just use JB Weld on it and it'll be good as new.
  #120 (permalink)
Old 10-08-2009, 08:06 AM
dcdoug's Avatar
Let's hope we don't have that conversation.
www.partskeeper.com
Rate This Thread:
