289 weber linkage
Enzo-
I finally figured out the linkage on my IDAs-I got a new throttle lever and drilled a hole in it about 5mm closer to the shaft axis and installed it on the passenger side. Now the carbs pull the same amount of vacuum at idle and above. I never doubted you were right; I just had a real hard time finding where the linkage needed to be adjusted and by how much. Thanks- You and Paula are the greatest! Tim Black tblackgt350@mindspring.com |
| All times are GMT -7. The time now is 08:14 PM. |
