Click on this link....
RPC R1025-T, | RPC
Triple pass Ford radiator $185 at Jegs. Coolant passes through the radiator 3 times instead of 1 time. Fits Street Beast perfectly, you'll need to weld a couple of tabs. You'll need a water pump pulley that is the same diameter or smaller than your crank pulley as it takes a little more flow than a single pass radiator. I have an Edelbrock water pump that came on the crate engine (Says Ford Racing but it's an Edelbrock) the pulley is 1/1 with the crank. I also turned my idle up to 900 RPM which will push more water. Take the cap off the radiator and you can see how much more flow just a few rpms will make. Also if you have cast iron heads 210 degrees is not worth blinking at. If your car stays 220 degrees or less no matter the conditions you are in I would leave well enough alone and stay with your combination
