Adjusting the idle
http://www.clubcobra.com/forums/holley-tuning/128414-adjusting-idle.html)
| genolan |
04-02-2014 08:04 AM |
Adjusting the idle
I decided to lower the idle after a nice ride last night and adjusted the idle screw and to my surprise the idle would not go any lower than 1000rpm. I checked the choke and it was wide open. Any ideas?
Originally Posted by genolan
(Post 1293636)
check the mixture with a vacuum gauge adjust that first, you could also make sure the secondaries aren't open a little at idle hindering the adjustment lower. hard to say more without being there....
| Rick Parker |
04-02-2014 08:42 AM |
The secondaries (on a four corner idle carb only??) have a very small screw accessed from the bottom of the baseplate. It is used to just barely open the secondaries. If they are open a little too much, they alone will support an above average idle speed even if the primaries are completely closed
| DanEC |
04-02-2014 09:24 AM |
It's probably what Rick said above but also check your throttle linkage (rod or cable) to be sure there is enough slack in it to allow the throttle to close a little more.
| ffr 1137 |
04-02-2014 01:16 PM |
Had that happen on the Stang with a 670SA. Eng off...hold throttle fully open...the red plastic piece on opposite side is holding primary open a little. Dislodge it. It's part of the elect choke but mine isn't hooked up so don't know why this happens.
| All times are GMT -7. The time now is 11:45 AM. |
