-   Ignition (http://www.clubcobra.com/forums/ignition/)
-   -   Ignition Module for Duraspark Distributor (http://www.clubcobra.com/forums/ignition/115367-ignition-module-duraspark-distributor.html)
ShelbyPower 04-28-2012 05:22 AM
I have a Duraspark distributor as shown in the photo. This is for a 351 Windsor motor. I don't have an ignition box, coil, or any other wires.
- What kind of ignition box and coil should I get for this distributor---what are the options?
-Will the wires needed come with the new ignition box or do they have to be purchased separately?
Thanks!
http://www.clubcobra.com/photopost/d...SC02790_2_.jpg
DAVID GAGNARD 04-28-2012 08:02 AM
Pretty much any "standard" type coil will work.....for an ignition box, you can use a Ford Duraspark box (very inexpensive) or any MSD type box, most have the adapter to plug into your distributor......
David
Roger Bolick 04-28-2012 11:52 AM
HEI module
If you have an original Duraspark vehicle with all the hookups and wiring, then its vastly easier to use the matching Duraspark Module.
If its a new installation and a Duraspark distributor is available (or you make one...), then just attach a 78 Camaro 350 HEI module. This is the 4 pin early version which is $18 new.
Higher performance HEI's are available, but if you heat sink this module external to the dizzy it will perform much better than buried inside the dizzy at the engine rear per GM.
1975 Ford Truck 390 FE Distributor (Duraspark) rebuilt, no core, Adv. Auto, $65.
1978 Camaro 350 Ignition Module (HEI), $18.
Heat Sink, $2.
Wire w/1/4 female spade connectors (7) and coil/ground connectors, $5.
TOTAL: $90
NOTE:
1. HEI module has FIVE (5) connections, mount screw is ground -> dizzy.
2. Power must be 12V, careful retrofitting ballast resistor setups.
3. Need heat sink and special grease (inc w/new HEI). (2x2x1/8x4 AL angle)
4. Tie all leads so vibration cannot separate spades.
5. Most Duraspark's came in trucks or large cars, recurve helps (see web).
6. Get rid of the large dizzy cap, use the 60's small cap & wires, its vintage correct.
(usually just remove the later adapter collar and voila it fits)
7. Converting an earlier Ford dizzy to Duraspark is easy, use a $10 5.0 donor.
8. Most popular 12V coils work.
9. Prefer not to cut dizzy leads as this complicates a field replacement.
Search the web for "duraspark HEI conversion".
Wiring Diagram for 5th graders here:
Dirt cheap Ignition
4SECA 04-28-2012 03:23 PM
Ford Dura-Spark Dist. uses the the same main componets as MSD does.I have run Duraspark dist with MSD 6AL Box,Mallory Box,Jacobs Ing. Box,and Ford MotorSport Box.
Watch the centrifical advance weight pins .They can be loose and fail under hard use . It is best to weld them before they cost you lots time and money.
I hope that helps....
Oh go to the MSD web site.Look at wiring diagrams.
ShelbyPower 04-30-2012 05:19 AM
Thanks for the replies...lots of good information. I opted for ease of installation and ordered a basic Motorcraft box for the Duraspark and a coil.
