Ignition spark plug wires
Hello.
I would like to replace the ignition spark plug wires .. it's a 302 Ford Engine. Can you recommend a good set ? ( Ebay link will be great ) Thank you :) |
I use the Jacobs or MSD 8MM ones and have had very good luck with them but I don't have an Ebay link. However they are pricey.
Ron |
Buy from a quality name. 8mm or larger seem to be geared towards performance. I wanted something in the range of "original look" so I bought black wires, Ford Racing.
I've used Taylor plug wires on a couple of engines with zero issues. I like to use their 8mm black cable set for custom assembly. That allows you to get the exact length and position right for each cable.
I am also a fan of the Taylor wires. I use the big "409 Series" which are 10.4mm. They can take high heat and have given me zero troubles.:cool:
409 Pro Race UNIVERSAL/Race Ignition Wire Sets - Taylor Cable Products |
I use "SX" for originality.
Tony Branda sells them. Always get comments at shows when noticed. |
| All times are GMT -7. The time now is 09:25 AM. |
