Like Tree1Likes
  • 1 Post By spdbrake
Old 07-30-2016, 08:28 AM
Cobra Make, Engine: Superformance MkIII Roadster
Default Replacement coil with quick connect posts?
I have a Kieth Craft 331 in my Superformance. The connection to the round coil is a push on plastic connector that engages special posts on either side where I would normally expect them to be threaded. What have I got and where can I find a reasonable replacement? Trying to fix an intermittent low speed bucking/stalling condition...
Old 07-30-2016, 09:01 AM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
Is this what you're looking for ?
https://www.summitracing.com/parts/rnb-85848/overview/
Ted
Old 07-30-2016, 10:48 AM
At Autozone as well
Duralast PN 252
Ignition Coil Connector for Cars, Trucks & SUVs
cdnus likes this.
Old 08-02-2016, 10:11 PM
Sorry I was not clear. I'm actually looking for the coil. Wondering what primary resistance to use with the MSD 6AL. I found a high performance Motorcraft coil since I posted. DG-316. It has a 0.7ohm primary - same as a Blaster 2 coil. Thoughts?
Old 08-02-2016, 10:22 PM
From The 6AL instructions:
COILS
The Digital 6A and 6AL Ignition can be used with most stock coils and aftermarket coils designed to replace the stock coils. The line of MSD Blaster Coils are great for street and mild racing. For extended high rpm operation the Blaster HVC, PN 8252 or HVC II, PN 8253, are recommended. For more
information on recommended coils, check with our Customer Service Department at (915) 855-7123.
You should be fine.
The DG-316 is for non-ballast resistor applications and thats you.
