01-23-2010, 10:19 AM
Ma
Cobra Make, Engine: Kirkham 592
What fuel log are you guys using with the turkey pan?
I had a nice braided one that doesn't fit
thanks
chris
01-23-2010, 11:19 AM
Cobra Make, Engine: Hurricane Motorsports, 427w
I had a local shop fab one for me. It's 3/8" hard line.
Matt
Hurricane Motorsports #1053; 427w
01-23-2010, 02:34 PM
Senior CC Premier Member
This is the setup I have. Flex and AN's to the carb. Take-off on back goes to the fuel pressure, which is a fluid isolator to keep fuel out of the cockpit.
01-23-2010, 02:53 PM
Ma
Those look very nice. I was looking for an off the shelf item. Is there an off the shelf line that will work with Kirkham's turkey pan?
01-23-2010, 03:35 PM
I picked one up at the local Kragen that fit mine.
Phil
http://www.uniquecobra.com/
01-23-2010, 07:08 PM
Cobra Make, Engine: CSX 4973
I have an extra one (came with my runner kit) that is for use with a turkey pan. I did not use it as I have dual quads. If your interested let me know. It looks like this one.
http://www.clubcobra.com/photopost/s...7/ppuser/27494
01-23-2010, 10:15 PM
Ma
I'm interested but are you sure it will fit a Kirkham turkey pan?
Chris
01-24-2010, 07:47 AM
UK
I've used a standard off the shelf Holley item. It also has a connection point for the Kirkham fuel pressure sender.
01-24-2010, 07:57 AM
Kirkham makes and sells some extensions that work great with the turkey pan.
Call Dave on Monday and ask about the setup. 801-377-8224
01-24-2010, 07:58 AM
I'm not sure. Does the Kirkham pan have different dimensions than other available pans? I have purchased some other components from Kirkham for my CSX and they work fine. Would it help if I took some measurements?
Chris
01-24-2010, 08:46 AM
Ma
I'll call Dave on monday to ask about the extensions
01-25-2010, 02:41 PM
Chris,
Let me know what you find out. Another cc member is now interested in my fuel log.
01-27-2010, 10:46 AM
Ma
David,
I tried to call Kirkham today but struck out. I will again try tomorow. What is the make of yours? Does anyone have a part number for a fuel log or feed that fits?
01-27-2010, 11:08 AM
IA
I had the same problem when fitting my turkey pan. If you're going for the original look, the commonly sold fuel logs only fit 3-2bbls and 2-4bbls, not a single Holley/turkey pan combo. And the repro hard line from the fuel filter to the log will be wrong, too. The correct log is unique, and sits a little further back along the valve cover than the 2bbl and dual quad versions.
I purchased my log from Motorsports International in California, but I'm not sure they're still around. Do a web search for their telephone number and give them a try.
I had to hand fabricate a hard line to fit, but I'm pleased with the results. I used a repro line as a template and added the necessary length/bends to mate with my log. It eliminates the brass 45 degree fitting at the front of the log as the line goes straight into the log. Looks factory, and doesn't leak.
01-27-2010, 11:32 AM
Summitt has quite a few versions. Some are adjustable.
http://www.summitracing.com/search/?...el%20log&dds=1
01-27-2010, 12:05 PM
Cobra Make, Engine: Contemporary CCX33344 with original bore 427 SO.
The single 4V Fuel log is available here
http://dearbornsteeltubing.homestead.com/homepage.html
Thats where I got mine...good guy
01-28-2010, 09:37 AM
Ma
I got in touch with Kirkham motorsports today. They are sending me a little set up they make with a bracket for my fuel pressure regulator. They gave me a good deal. I can't ewait to get this thing togethere!
Chris
01-28-2010, 08:44 PM
Ut
Sorry I haven't been in lately. I have been working on a special project.
01-29-2010, 01:59 AM
Ma
No problem I'm all set now
Chris
