Old 05-14-2026, 08:14 AM
Cobra Make, Engine: Kirkham 599 Polished Bronze
Default Brake light activation switch
I just acquired a new (used) Kirkham and the brake lights work, but you need to mash the pedal down very hard to activate the lights. Is the activation switch in the box under the footwell? Does anyone know if the switch is adjustable?
Old 05-14-2026, 10:58 PM
Exclamation
Often it is activated by a pressure switch in the brake system, so that when you activate the pedal, pedal pressure turns on your lights. Look for something in line in the brake system near your master cylinder.
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 05-15-2026, 07:17 AM
Paul, I see some sensors coming off the master cylinder. I will explore this more. The Austin Cobra club is meeting tomorrow, so I'll pose the question to folks at the get together.
Old 05-21-2026, 09:52 PM
Thumbs up
Sounds great! Let us know what you find out. Good luck.
Paul
Old 06-03-2026, 02:00 PM
If on the brake line then it's an easy fix.
Mashing the peddle to get activation is a sign it's failing.
Ask me how I know.
I replaced mine with Allstar ALL76251 (bullet connector)
You can also use Allstar ALL76252 (two wire screws)
Rated at 60-120 PSI and 4.5 amps.
Old 05-18-2026, 10:16 AM
Cobra Make, Engine: built the molds and body composite construction
If you have a pressure switch, take a look at Amazon and pick one with a low activation pressure and the thread and electrical push on which matches your present system, so it becomes a simple exchange. The low seems to be 45 lbs, some switches come with 60 lbs for there low you want the lowest you can get.
BillK
