Hinge Cover for a Kirkham?
Rob,
The ones from CobraRestorers will fit the Kmp, although a little snug. I've been told, by someone that has done quite a few original restorations, that they had two screws mounting the covers like in the photo below. http://www.clubcobra.com/photopost/d.../SAAC32018.jpg The trick, from the same person, is to take a small amount of material off the front edge on the hinge such that it is easy to slide the cover on and off. Then you mount a piece of wood between the rails, yes that what I was told, and that is what the screws will attach to. Scott |
You can get then from Hawkcars UK! www.hawkcars.co.uk
Got some plastic ones from CobraRestorers and some glass ones from Shelby...the glass ones fit better, and just slide on tight/no screws needed.
The ones that I got from CobraRestorers are fiberglass and do slide on rather snuggly without screws. They have popped off before and that is why I'm converting over to the screw method. Also, I don't like how snug they fit as it causes the cover to flex a fair amount when installing. It is probably just the combination of the cover and my hinges that make the fit a lttle less than I like.
Best of luck, Scott |
What Jamo said. Call SAI.
| All times are GMT -7. The time now is 08:35 AM. |
