Old 05-12-2009, 09:39 PM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Default Kirkham radiator
Who is the source for the radiator in the early Kirkhams (185)? I have a pin hole in the core which is temporarily sealed with good ole Bar's leak. I want to price a new one.
Dave
Old 05-13-2009, 05:45 PM
Far as I know they're all Fluidyne, Summit racing and a bunch of others carry them.
Old 05-13-2009, 05:53 PM
4pipes's Avatar
Thanks, you're right.....FHP30-SHELBY
Dave
Old 05-13-2009, 06:05 PM
Got the Bug's Avatar
Is it possible or worth it to have it repaired?
Doug
Old 05-13-2009, 08:14 PM
4pipes's Avatar
A new one is $470. I doubt if anyone can touch it for that! It's leaking in one of the cores and it's aluminum. Heli-arc'd together.
Dave
Old 05-13-2009, 08:15 PM
Considering the cheapest I've found one of these radiators is around $515, it might be worth trying to get a radiator shop to repair your existing one.
I got incredibly lucky and picked up a good used one on ebay for $36, but it will need a little bit of cleaning up and possibly a little repair work. I figured I can get a lot of repair work done for the price difference.
Old 05-13-2009, 09:55 PM
Unless it's a minor weld defect...
Where there's one pinhole there's another five waiting to come to the surface. Unless it's getting ready to be someone else's problem, just replace it. (cheaper than a warped head)
Old 05-13-2009, 10:28 PM
Jamo's Avatar
Super Moderator
Dave...new one...don't look back.
Jamo
Old 07-08-2009, 08:36 AM
Cobra Make, Engine: KMP-216S Kirkham Street '66 428 PI
4 pipes, I don't know if this is too little too late but I had to replace my rad. and got the fluidyne as mentioned. It's about a half an inch thicker than orig. and that half an inch is a *****.
Had to grease the bottom hose to get it past the steering arm, amongst other things.
Talked to Kirkham and they said the early rads were all custom made and the orig fabricator went out of biz. Fluidyne is the new source.
You'll need new brackets from Kirkham to mount the fan properly.
But, you probobly figured all this out by now.
K
Old 07-08-2009, 10:15 AM
RodKnock's Avatar
K
Good information to know nonetheless. Thanks.
Old 07-08-2009, 11:18 AM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
I got from this guy, made him an offer of $475 and he accepted. This included shipping.
http://cgi.ebay.com/ebaymotors/FLUID...Q5fAccessories
Cobrarich
Old 07-08-2009, 01:42 PM
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
If that's an actual picture of the radiator it sure isn't the same as what's in my car.
Old 07-08-2009, 02:26 PM
4pipes's Avatar
That's not the right picture. My radiator is installed already. I'm picking up my car Saturday. My fabricator happened to have one of his "upgraded" radiators for the Kirkham. It has a baffle half way down from the inlet so hot water can't just drop down to the bottom. We also added a differential cooler to my car. I fried the clutch pack at the track and so ergo... the cooler.
Dave
Old 07-09-2009, 06:59 AM
cobrarkc's Avatar
That is just a stock photo, check the part# it's the replacement for a cobra.
Cobrarich
Old 07-09-2009, 07:38 AM
Rick Parker's Avatar
The only part on an aluminum radiator that can be repaired by Tig welding would be the tanks. The heat necessary to weld will destroy the fins or tubes A hot melt Glue gun might surprize you though, I've seen it done Consider pinching the offending tube at the header plate to reduce or eliminate flow in the single tube and apply a little hot melt glue. It sounds hokey but it works. Used a lot by the circle track crowd in a jamb.
Old 07-09-2009, 10:37 AM
David Kirkham's Avatar
Our original source for radiators was Ron Davis Racing Radiators in Arizona. Over time, we found his fin count was too high for street use. The high fin count blocked air flow at low speeds (and high speeds too for that matter) and so the motors would heat up more putting around. At high racing speeds, the high fin count could take advantage of the forced air. For us weekend warrior types, we simply don't track the car very hard so the lower fin count doesn't matter.
For the past few years, we have used a custom radiator shop to make our radiators. We have also used Fluidyne when we couldn't get radiators fast enough from our supplier. Now we are back to using our custom radiator shop. He does extremely nice work.
As for welding a fin...it would take a magician. As for hot glue--hey, whatever works, but I'm not sure I'd trust it too far.
