Go Back   Club Cobra > Club Forums > NorCal Cobras
Old 05-06-2007, 09:20 PM
DocDirk's Avatar
Cobra Make, Engine: West Coast-Ford Performance Solutions 533 BB
Default Hood scoop Design
Thanks for the look, folks. My new West Coast kit has a taller hood scoop to accommodate the larger engine I'm putting into it. It is OPEN on the window side and I'm wondering if anyone knows how the airflow through the scoop will affect intake air flow. I'm considering closing the scoop there if it makes sense. The builder says the windowside opening will aid in engine compartment temperature control...I've been reading forum posts on hood scoop function and it's pretty confusing! I think the consensus is that the opening ought to be at the window ONLY for the high pressure benefit there
Dirk
Old 05-07-2007, 04:50 AM
Dirk, short answer, I'd say no effect on intake flow if you run an air filter and proper cleaner assembly.
From what Pete found on the coupe testing, I wouldn't be surprised if you actually have air flowing in the back and out the front like he did with the coupe (if you seal it to the carb or motor). If so, the venturi effect past the carb "might" cause some problems, but I doubt it, since the air coming in the back would go into a larger area (the turkey pan or engine compartment) and tend to pressurize that area before air exited at the front opening. I'd bet the air speed past the air cleaner would likely be low, and the main benefit would be cool air, not ram air (I think you get like 1.5-2% benefit from ram air at 150 mph, but maybe 5%+ from cool air regardless of the speed).
JMHO
Ken
