| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
06-10-2009, 01:26 AM
CA
Cobra Make, Engine: Superformance Roush 327 R
tech question
when the engine is running the tach, fuel gauge, blinkers dont work...when i am not running the engine everything works except for the tach obviously...alternator or battery is bad...also when there is a full battery attached to the on board battery everything works...help please
 the more you know the more you know you dont know
06-10-2009, 05:37 AM
voltage
A low voltage problem most likely.
First thing to check is engine to frame ground.
Battery connections
Wiring to alternator next
Then check voltage while running. Should be 13.6 volts at the battery minimum
06-10-2009, 08:01 AM
CA
You could hire a Porsche to follow you and help with a jumpstart as needed!
"Live Life Abundantly"
06-10-2009, 08:36 AM
CA
What 747 said plus you might have the battery load tested. A bad cell can cause the alternator to not be able to charge it and keep the voltage up, but normally it would also be low when the car is stopped.
06-10-2009, 09:57 AM
CA
were you at crush 29 last night?
06-10-2009, 10:49 AM
NC
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
Don't listen to Jrmac1 (John).... Just ask him how a GTO runs on 7 cyl. That'll shut him up!!! See me for details!!!
A lot of modern electronics require more than 10 volts just to function. Anything less and they act ADHD.
Step 1...Swap the battery out of you wife's car and put it in the Cobra.
Step 2...If that cures the problem, go to Step 3.
Step 3...When she tells you the "Family Truckster" won't start you say "It needs a new battery".
Step 4...Buy a cool new Gel Battery and swap it back into the Cobra during the early hours of the morning while she's asleep.
Step 5...If that fails, refer to 727's instructions!
PS.... This works for an array of other situations. Tom
Tom
I miss my Tazer
06-10-2009, 11:31 AM
Ca
With the engine running at idle, turn on the headlights.
Are they on? Does the engine die? Are they bright or dull? Now rev the engine. Do they get brighter when revved? Battery or ground.
Jim
06-10-2009, 11:43 PM
CA
Don't listen to Tom either...just ask him how a Chevy Tahoe runs with mud up to the floorboards!!!
06-11-2009, 11:38 AM
NC
It ran on all 8 though!
Tom
I miss my Tazer
06-11-2009, 12:53 PM
CA
you guys are hilarious...mostly not helpful but hilarious...changed the alternator and voltage regulator and voi la...thats french for the damn thing is fixed...
06-11-2009, 06:30 PM
CA
Hey culdad, yes I was there next to the Chevelle. Glad you solved the electrical issues.
Hey Tom, the only 8 you were running on was the 8 in the truck that pulled you out!
06-11-2009, 11:13 PM
NC
Bite Me. Remember....the 8th plug wire is not just a spare!!!
Tom
I miss my Tazer
06-11-2009, 11:27 PM
CA
Tom...it's past your bedtime.
06-12-2009, 10:27 AM
NC
Fine.......
Tom
I miss my Tazer
06-12-2009, 02:03 PM
Regularly Offensive
ca
Cobra Make, Engine: spf
Did you check your tire pressure?.........................
Ed
Too close for missles, switching to guns.........
