Go Back   Club Cobra > Club Forums > NW Cobra Club
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-17-2004, 11:53 AM
Cobra Make, Engine: building someone elses E&M 1967 427 side oiler
Default Front plates
I was wondering if any of you guys have mounted your front plates ob your cobras?
I really dont know if the cops will mess with me or not so I figured I would ask you guys what you have done so I dont get pulled over on this weekends run.
Matt
Old 08-17-2004, 02:36 PM
JayBar's Avatar
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
Here is one that mounts to the front quick jack (of overrider) rods.
http://www.cobraaccessories.com/cata...roducts_id=178
a quality piece.
JayB
Jupiter, FL
Old 08-17-2004, 10:23 PM
Jake's Avatar
Cobra Make, Engine: Superformance Cobra #1628, Coast Performance Stroker 427W Ford 520HP/535FT.TQ, Blue with white stripes
Matt, I would not get to excited over the front plate issue. I have not had a front plate for 2 years and have never been messed with by the cops. Most law enforcement are to busy dreaming about the car to notice the plate.
My 2 Cents, Jake
Old 08-17-2004, 10:51 PM
I was thinking about not putting it on and just putting it behind the seat. And thats what I will do.
Matt
Old 08-17-2004, 11:31 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
That's where my was on the SPF and where it resides in my FIA--WA resident--been stopped and so far never questioned about it--knock on wood
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 08-18-2004, 08:47 AM
Cobra Make, Engine: A&C 427SC #188 ZZ4 Crate, Tremac 3550
Send a message via AIM to Bish Wheeler
Had the front plate on for a while. I tie wrapped it to the oil cooler scoop, but kept dragging it on the road and knocking it off so removed it and put it in the trunk. Been stopped a couple of times, once because of no plate, but the trooper really just wanted to see the car and agreed that there really was no good place to put it and started asking how the car handled, how fast, etc. etc. I don't think you need to worry about it, but keep it with you.
Bish
Old 08-18-2004, 09:09 AM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default I simply cable-tied mine to the bottom of the front hoop
It pivots away/under when driving and does not hit my paint so it's OK but it does detract from the car's looks a bit when sitting still. Front plates are a dumb idea anyway and many states do not require them. I will agree that most street cops are too busy having a daydream of owning your car to notice the plate issue..
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
Old 08-21-2004, 07:15 PM
Scott S's Avatar
Charter Club Cobra Member
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
I was pulled over for no front plate, I told the cop that front plates were not standard equiptment in 1965.
He believed me and let me go.
Scott S
Working as hard as I can every day to double my carbon footprint.
Old 11-07-2004, 03:40 PM
Cobra Make, Engine: Sold my FIA Cobra to MrMustang
I haven't had a plate on the Cobra since it was built in 1999. No cop has even mentioned it. I've been stopped a few times but never ticketed yet. Knock on wood. I keep both plates bolted together on the rear, just so I don't loose the other plate.
www.bloodenterprises.com/cobra
Adam Crabtree
www.sportscarguyspeaks.com
Old 11-08-2004, 10:04 AM
rdorman's Avatar
Renegade Nuns on Wheels
Knock on wood as well. Over 2.5 years with no front plate and not only have I not been stopped for it, in all the times I have stopped and spoke to cops, not one has mentioned it. If I had to put one on, I always that I would hing it up in the nose and hold it up with a pin removed from the cockpit by a cable. If I ever get pulled over, pull the pin, front plate. I would be interesting to see their reaction when the look and see the plate.
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 11-08-2004, 09:49 PM
Brent Mills's Avatar
Administrator
Had a Cobra since 1999 and have not had a front plate. I keep it in the car, but nobody has asked about it....Even when I got pulled over for speeding supposedly, the guy didn't mention anything about the plate not being on my Corvette....Yup, he gave me a ticket and called the Cobra a Corvette. Grrrr....It was several years ago, so no biggie now, but geez.
Old 11-08-2004, 10:10 PM
G.R.'s Avatar
Most patrolmen, unless you were really doing something stupid, won't really check or care about the front plate or lack of. Have you ever been stopped for any reason in your daily driver? Did the officer ever check for a front plate? Sort of a moot point, yet there is always the "one" that will be a stickler for "the rules".
Too bad we can't use the Euro style nose plates--just print your plate number on static cling, remove when you want
Old 11-09-2004, 03:12 AM
BMK's Avatar
BMK BMK is offline
rdorman
My plate is on hinge and swings up when moving.
Now I've seen the DVD of the DVSF and have seen the thumbs-up the Police there give you guys there when you drag down the main street..
Bernie
Bernie Knight
Old 11-09-2004, 07:15 AM
luke-44's Avatar
a quality piece.
I mounted this to my ERA - basically straight forward, but a few tricks I learned in the process...good luck. Here is the thread
Finishline License Plate Holder Instal on ERA
Bruce
Enjoyment may be 9/10's anticipation, but that last 10% is oh so sweet....
Old 11-09-2004, 05:04 PM
djseed's Avatar
30 Year Wait is Over
Cobra Make, Engine: SPF 1630 '70 429 SCJ / 501
In Ontario, Canada it is illegal to run without a front plate. The fine is over $100. I used the standard issue SPF license plate plate bracket that mounts to front passenger side lower turn signal. A photo of the bracket and plate are in my gallery.
David J. Seed
Q: What makes a good racer?
A: Size 14 shoe, size 2 hat.
Buddy Baker, NASCAR Hero
Old 11-09-2004, 10:13 PM
HI Cobra's Avatar
I have a black wire grill 1"x3" mounted about 3"
inside the air scoop to keep large things off the
radiator. I used small stainless steel rings to hang
my front license plate from the top behind the grill
centered in the opening. It swings back once I get
going so does not affect cooling at all and really isn't
that noticeable when stopped.
Flip
Old 11-10-2004, 08:39 PM
Zderf's Avatar
Cobra Make, Engine: VICTORY, 92 C.I., belt drive, saddle bags.
Exclamation Been Stopped Once
King County Sheriff. Walked past the drivers door and headed for the front of the car. Noticed a slight grimmace when he saw my front plate. Didn't get tickedted, but I'm thinking he whould have hammered me on the missing plate had it been so.
Jake... you've got major slack and lack of concern.. for some reason, eh?
Respectfuly,
Zderf
Old 11-28-2004, 01:41 PM
40k Later's Avatar
In Washington of course the law says "A front plate must be displayed in clear view" I had a WSP North of Marysville pull ahead of me for a brief second or two and then back off the throttle and point to the front of the car. I thought he wanted me to pull over and so I slowed and moved to the right but he kept going. I can only assume he was looking for a plate. I have since zip tied mine to the front sway bar and If I ever get it in a car show I'll cut it off when I get there. I must say however, countless law enforcement from Sheriff to tribal Police have passed or have been passed and most of them had their thumbs up!
Old 11-28-2004, 02:05 PM
Junket's Avatar
Cobra Make, Engine: shell valley
I have a State Cop that lives down from me and ask him casually about the plate thing said he had better things to take up his time but but it could give a reason for a stop on leaving he casually made the coment on the lack of mine and smiled
Ken
Talent is your head in communication with your balls.
