November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
07-28-2008, 10:30 AM
wa
Cobra Make, Engine: Everett-Morrison, 347 Stroker
Need a windshield
I am looking for a windshield for an Everett Morrison. I have tried to contact them with no reply. I think we should have a customer satisfaction section on this web site and see what cobra maker provides the best overall service. This would be helpfull to future buyers of cobras.
Jim
Advertising
07-28-2008, 11:28 AM
WA
Cobra Make, Engine: FFR, Carb 302
Jim,
Do you know if perhaps a windshield from another manufacture might work?
Make a cardboard template of yours and compare it to my FFR or Jake's Superformance to see if they might work. I personally know both companies have excellent customer service.
07-28-2008, 03:24 PM
WV
Cobra Make, Engine: 351 Windsor
I also have an E-M and had to replace my windshield. I bought through Finish Line and it worked perfect.
07-28-2008, 04:40 PM
I just bought a new windshield from Finishline. They don't come cheap!
07-28-2008, 05:02 PM
AL
Lexan
1/4" tinted Lexan is a choice. Remove old glass, make a paper template and transfer to a sheet of Lexan. We bought a couple of pieces from a local auto glass shop. Use a Rotozip or saw to cut the Lexan. Sand the edge smooth. Install in old frame. Should cost less than $200.
Dwight
Rotozip DR01 w/ Soft Handle, 2 XBITS, Bit Case & Collet Accessory Pack
Sears item #00988438000
Mfr. model #DR01-1100
$69.99In stock for deliverySpecial Offers
07-28-2008, 05:12 PM
Ca.
From what I understand, all of the windshields are the same for all of the makes of Cobras. Mine was just over $300.00 from Finishline.
Though, If I have to do it again I am thinking about Lexan. I believe you have to put in a thicker gasket between the windshield and the frame. The glass is just a bit thicker.
Terry
07-28-2008, 05:34 PM
AL
Glass
I have seen two different windshields for Cobra. I just checked Finishline and their price for glass is $495. Make sure it fits before you buy.
Dwight
07-28-2008, 09:21 PM
wa
Thank You all for your advice.
Steve, If you had not told me I had a few screws loose I would have not tightned my windshield visor so tight.
Jim
07-28-2008, 09:28 PM
Ca.
Dwight
Wow, I am going to have to re-look at my receipt. Two different windshields, Huh, I'll have to look into that.
Terry
P.S. I just looked at my invoice and the windshield glass was $295.00 in Jan. 2008. The price must have really gone up.
Reason: added P.S. info
07-28-2008, 09:41 PM
wa
For those who have tried Lexan, are you satisfied with the clarity and how about cleaning it. Does the Sun yellow it or make it brittle?
Thank's
Jim
07-29-2008, 04:58 PM
wa.
Cobra Make, Engine: Superformance Cobra #1628, Coast Performance Stroker 427W Ford 520HP/535FT.TQ, Blue with white stripes
Jim, if you do find a windshield. The Speedy auto glass on 126th and Meridian is well versed on Cobra windshields and will take on the cause for you. They are fixing the red SPF as I write this. The number is 848-9538 and ask for John.
Jake
If your going to dream, dream big!
08-02-2008, 11:31 PM
wa
Just recieved letter from Everett Morroson.
New windshield is $ 1,200.00 plus $65.00 Shipping!!!!
New windshield with frame on Ebay $ 700.00
Jim
08-03-2008, 01:04 AM
va
Cobra Make, Engine: BDR #250
Check with your insurance company most have a windshield replacement clause where they will replace the glass from "road damage" for as little as $100 deductable.
08-04-2008, 03:21 PM
ID
Cobra Make, Engine: Superformance #1688, Indigo Blue, Titanium Stripe, 393 Stroker
Hi Jake,
What are you having to pay to get a new windshield installed?
Marshall
08-04-2008, 08:40 PM
WA
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
As I remember there are two types of windsheilds domestic and european . I have an older EM with the domestic strain. I ordered my glass through Bob Kalo at Shell Valley- Mid States
Mike H
08-04-2008, 11:16 PM
CA
I have had a Scratch resistant Lexan windshield on for 21 yrs and it still works OK ,although it does have a few scratches, but none from the wipers and I have used them a bunch. Absolutely no discoloring .I had a crash and the Lexan screen broke a tree branch,which left a good scratch.
I recently bought a new piece and made extra large SideWings at the same time. The Lexan is so tough that you can jigsaw and drill without cracking.The sides just use 800 grit waterpaper and then finish with 1500 and it looks just like glass,but will not break.
John
08-05-2008, 05:30 AM
OK
I went to Lexan about three years ago after replacing three windshields in less than a year. I will not pay $500 or more for my Cobra Windshield again. Actually, for about $100 you can get enough Polycabonite to make two windshields if you don't mind cutting them out yourself. Plastic Engineering here in Tulsa will cut them for you and you have $80 or you can but a sheet and cut your own for just a little more.
Clois Harlan
"Let's roll"
"Be part of Something Good
08-07-2008, 11:29 AM
wa
Well, I ended up ordering a windshield on Ebay. I will go to lexan on the next one. I needed two windshield frames. One cut to about 1/2 original height and one normal height. I saw a cobra with a 1/2 or 1/3rd windshield and it looked great. He only used the side windshield frame with no top frame. Sounds bad, but adds a compitition look that I like.
Jim
