November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-10-2010, 02:45 PM
Default Lucas firewall wiring
Guys, got 3 weeks off from being Dad (the ex has taken my son to australia for a holiday)! so time to crack on with the car
i trial fitted the lucas components to the firewall today. but can anyone tell me the color coding used for the relays, fusebox and rear light box etc. its only decorative on my car, ( as i dont trust the reliability), but for authenticity-sake i wanted it all to look correct. so i want to make up a run of dummy loom for these bits that is color-coded correct.
cheers,kevin
Crendon 427, in the making
http://crendonreplicas.com/
Old 01-10-2010, 04:50 PM
Send me an email (eracars <at> sbcglobal dot net and I'll email you back an original wiring schematic.
Old 01-10-2010, 05:02 PM
thanks - pm sent.
Old 01-10-2010, 10:48 PM
289ACE's Avatar
Cobra Make, Engine: 2 AC Aces, 1 w/289, 1 w/TBD
This might also help. It explains what colored wires are used for what connections.
http://www3.sympatico.ca/peter.mcker...on/wiring.html
Jay
Old 01-10-2010, 11:36 PM
PANAVIA's Avatar
Wiring Colour Code Table
This is an extract from BS-AU7a 1983 Colour Code for Vehicle Wiring, from the British Standards Institution.
(Note that these colour codes may not apply directly to older cars. )
For example, the wipers on cars up to 1980 (at least) are not on a separate fuse circuit, so they are not orange, but green.
Check the schematic for your car to be certain.
MAIN TRACER PURPOSE
BLACK/BLACK/BLACK/BLACK/
Black /Solid: All earth (ground) connections
Black/Brown: Tachometer generator to tachometer
Black/Blue: Tachometer generator to tachometer
Black/Red: Electric or electronic speedometer to sensor
Black/Purple: Temperature switch to warning light
Black/Green: Relay to radiator fan motor
Black/LightGreen: Vacuum brake switch or brake differential pressure valve to warning light and/or buzzer
Black/White: Brake fluid level warning light to switch and handbrake swith, or radio to speakers
Black/Yellow: Electric speedometer
Black/Orange: Radiator fan motor to thermal switch
BLUE/BLUE/BLUE/BLUE/
Blue Solid: Lighting switch (head) to dip beam switch
Blue/Brown: Headlamp relay to headlamp fuse
Blue/Red: Dip switch to headlamp dip beam fuse - Fuse to right-hand dip headlamp
Blue/LightGreen: Headlamp wiper motor to headlamp wash pump motor
Blue/White;
a)Dip switch to headlamp main beam fuse
b)Headlamp flasher to main beam fuse
c)Dip switch main beam warning light
d)Dip switch to long-range driving light switch
Blue/Yellow: Long-range driving light switch to lamp
Blue/Black: Fuse to right-hand main headlamp
Blue/Pink: Fuse to left-hand dip headlamp
Blue/SlateGrey: Headlamp main beam fuse to left-hand headlamp or inboard headlamps when independently fused
Blue/Orange: Fuse to right-hand dip headlamp
BROWN/BROWN/BROWN/
Brown Solid: Main battery lead
Brown/Blue: Control box (compensated voltage control only) to ignition switch and lighting switch (feed)
Brown/Red: Compression ignition starting aid to switch , Main battery feed to double pole ignition switch
Brown/Purple: Alternator regulator feed
Brown/Green: Dynamo (Generator) *F* to control box regulator pole *F* or Alternator field *F* to regulator *F*
Brown/White: Ammeter to Regulator, Ammeter to main alternator terminal
Brown/Yellow: Alternator to 'no charge' warning light
Brown/Black: Alternator battery sensing lead
Brown/SlateGrey: Starter relay contact to starter solenoid
Brown/Orange: Fuel shut-off (diesel stop)
GREEN/GREEN/GREEN/GREEN/
Green Solid: Ignition switch accessories / fused
Green/Brown: Switch to reverse lamps
Green/Blue: Water temperature gauge to temperature unit
Green/Red: Direction indicator switch to left-hand flasher lamps
Green/Purple: Stop lamp switch to stop lamps, or stop lamp switch to lamp failure unit
Green/Lt.Green: Hazard flasher unit to hazard pilot lamp or lamp failure unit to stop lamp bulbs
Green/White: Direction indicator switch to right hand flasher lamps
Green/Yellow: Heater motor to switch single speed (or to 'slow' on tow- or three-speed motor)
Green/Black: Fuel gauge to fuel tank unit or switch, stabilizer to tank units
Green/Pink: Fuse to flasher unit
Green/SlateGrey;
a) Heater motor to switch ('fast' on two- or three-speed motor)
b)Coolant level unit to warning light
Green/Orange: Low fuel level switch to warning lamp
LT.GREEN/LT.GREEN/LT.GREEN
Lt.GreenSolid: Instrument voltage stabilizer to instruments
Lt.Green/Brown:Flasher switch to flasher unit
Lt.Green/Blue;
a)Flasher switch to left-hand flasher warning light
b)Coolant level sensor to control unit
c)Test switch to coolant level control unit
Lt.Green/Red: Fuel tank changeover switch to right-hand tank unit or entry and exit door closed switch to door actuator
Lt.Green/Purple: Flasher unit to flasher warning light
Lt.Green/Green: Start inhibitor relay to change speed switch; or switch to heater blower motor second speed on three-speed unit
Lt.Green/White: Low air pressure switch to buzzer and warning light
Lt.Green/Yellow: Flasher switch to right-hand warning light; or differential lock switch to differential lock warning light
Lt.Green/Black: Front screen jet switch to screen jet motor
Lt.Green/SlateGrey: Fuel tank changeover switch to left-hand tank unit; or entry and exit door open switch to door actuator
Lt.Green/Orange: Rear window wash switch to wash pump or cab lock-down switch to warning light
ORANGE/ORANGE/ORANGE/ORANGE/
OrangeSolid: Wiper circuits fused via ignition switch
Orange/Blue:Switch to front screen wiper motor first speed timer or intermittend unit
Orange/Green: Switch to front screen wiper motor second speed
Orange/Black: Switch to front screen wiper motor parking cicuit, timer or intermittent unit
Orange/Purple:Timer or intermittent unit to motor parking circuit
Orange/White:Timer or intermittent unit to motor parking circuit
Orange/Yellow:Switch to headlamp or rear window wiper motor feed, timer or relay coil
Orange/Lt.Green: Switch to headlamp or rear window wiper motor parking circuit timer or relay coil
Orange/Pink: Timer or relay to headlamp or rear window wiper motor feed
Orange/SlateGrey: Timer or relay to headlamp or rear window wiper motor parking circuit
Pink/white: Ballast terminal to ignition distributor
PURPLE/PURPLE/PURPLE/PURPLE/
PurpleSolid:Accessories fed direct from battery via fuse
Purple/Brown:Horn fuse to horn relay when horn is fused separately
Purple/Blue:Fuse to heated rear window relay or switch and warning light
Purple/Red:Switches to map light, under bonnet light, glove box light and boot lamp when fed direct from battery fuse
Purple/Green:Fuse to hazard flasher
Purple/Lt.Green:Fuse to relay for screen demist
Purple/White : Interior lights to switch (subsidiary circuit door safety lights to switch)
Purple/Yellow : Horn to horn relay
Purple/Black : Horn to horn relay to horn push
Purple/Pink : Rear heated window to switch or relay
Purple/SlateGrey:Antenna motor to switch *up*
Purple/Orange : Aerial lift motor to switch down
RED/RED/RED/RED/
RedSolid :Main feed to all circuits mastered by sidelamp switch
Red/Brown :Rear fog guard switch to lamps
Red/Blue :Front fog lamp fuse to fog lamp switch
Red/Purple :Switches to map light, under bonnet light, glove box light and boot lamp when sidelamp circuit fed
Red/Green :Bulb failure unit to right-hand-side and rear lamps
Red/White ;
a)Sidelamp fuse to right-hand side and rear lamps
b)Sidelamp fuse to panel light rheostat
c)Fuse to panel light switch or rheostat
d)Fuse to fibre optic lamp source
Red/Yellow:Fog lamp switch to fog lamp or front fog fuse to fog lamps
Red/Black:Left-hand,sidelamp fuse to side and tail lamps and number plate illumination
Red/Pink:Sidelamp fuse to lighting relay
Red/SlateGrey:Lamp failure unit to lef-hand side and tail lamps
Red/Orange :Fusebox to rear fog guard switch
Red/SlateGrey :Window lift main lead
WHITE/WHITE/WHITE/WHITE/
WhiteSolid:Ignition switch or starter solenoid to ballast resistor
White/Brown:Oil pressure switch to warning light or gauge, or starter relay to oil pressure switch
White/Blue:Choke switch to choke solenoid (unfused) and/or choke to switch to warning light, or electronic ignition distributor to drive resistor
White/Red:Starter switch to starter solenoid or inhibitor switch or starter relay or ignition (start position) to bulb failure unit
White/Purple:Fuel pump no 1 or right-hand to changeover switch
White/Green:Fuel pump no 2 or left-hand to changeover switch
White/Lt.Green:Start switch to starter interlock or oil pressure switch to fuel pump or start inhibitor switch to starter relay or solenoid
White/Yellow:Ballast resistor to coil or starter solenoid to coil
White/Black:Ignition coil contact breaker to distributor contact breaker, or distributor side of coil to voltage impulse tachometer
White/Pink:Ignition switch to radio fuse
White/SlateGrey:Current tachometer to ignition coil
White/Orange:Hazard warning lead to switch
YELLOW/YELLOW/YELLOW/YELLOW/
Yellow :
a)0verdrive
b)fuel injection
c)Door locks
d)Gear selector switch to start
