Remote oil filter - originality 'compliant'?
What's the thinking on originality for remote oil filters on 289 cars? Did any of the race cars have this feature?
I'm 'over' horizontally fitted filters, fitted low down where accessibility isn't good, that piddle hot oil and make a mess when removing. Thoughts of the desirablility of a remote filter emerged again while changing the oil and filter on my ol' girl (Alfa) and as usual, hot oil everywhere no matter how quickly I try to spin off that filter. So....is it kosher, what sort should I be looking at and where should it be mounted? Cheers, Glen |
Great question Glenn! I, too, would like to hear what the historians have to say about this. Gentlemen... ?
I have never seen a remote fitted to an original 289 comp car.Remember not too many had oil coolers and those that I`ve seen were routed from cooler to sandwich block.
I mounted mine on the right hand bottom corner of the front shock tower to keep it period looking but at the same time preventing oil mess whilst changing filters. Ross |
1 Attachment(s)
Here is what I did using a Canton remote oil filter adapter.
All that I am aware of was the machined aluminum "sandwich style" adapter. GT40 MKIs and the first GT350 R Models all used something similar. Like most SAI race parts all of them might have been a little different depending on who machined them. I have seen a few 1963-64 SAI race shop drawings for race parts and most are not much more than outlines, i.e. fine details were not given.
Long ago I bought a NOS second generation GT350 R cast aluminum adapter that points the filter down. Wouldn't fit in the space available in CSX2310 so I sold it. |
Cheers, Glen |
Cheers, Glen |
Thanks for the pic Snakebit.
What sort of adaptor goes onto the original filter mount? I've looked at a number of websites, and most only show the filter mount and not the adaptor at the other end. Cheers, Glen |
Canton makes the filter adapter that mounts to the block and the billet remote filter adapter. Transdapt also has a similar set up. With my ERA, there was only room for a short filter between the block and the frame. I made the aluminum mounting bracket out of 5/16" aluminum plate. Just make shure it sits high enough for the filter to clear the fuel pump.
Dan - do you know if the Hayden filter adaptors are still available? I found the Hayden oil coolers, but not the adaptors.
Cheers, Glen |
I have seen them in ebayŽ listings by Hayden™ dealers. There are several models available depending on your application. I would think that any large RV dealer's parts department would be a source. Hayden was a (might still be) an O.E. supplier. Shelby American used their equipment and for a while in the late 1960s sold kits out of their catalog. Ford sold kits for a long time too through their racing parts business. Dan PS Just did a quick search "hayden adapter" on ebay and ones offered by Summit Racing came up first. |
Found it thanks Dan. I should look on eBay first....
Cheers, Glen |
| All times are GMT -7. The time now is 10:10 AM. |
