Like Tree1Likes
  • 1 Post By Dominik
Old 05-02-2013, 03:05 AM
Default 427 Oil cooler housing
Does anyone have any good pics of the original oil cooler housing? I plan to have a go at making one in the near future and want to be as close to original as my skill level will permit.
I have some pics, but it seems to me that Shelby changed the design on the continuation series compared to CSX3XXX series.
I have got various pics, including the one in the Rinsey Mills book. But none seem to show the area just to the side of the oil cooler housing itself. On Continuation cars it seems that the potential aperture between the rad and the nose to the side of the oil cooler housing is filled with a single piece of horizontal ali with a 1" or so lip thats rivetted along at the bottom of the radiator assembly. On older cars it seems this was a different design.
Crendon 427, in the making
http://crendonreplicas.com/
Old 06-16-2013, 04:18 AM
Dominik's Avatar
Kewin, in Old Hampshire, I have a drawing of that oil cooler housing from CSX4000 somewhere in storage.
Remind me to look for it... - or ask Mickmate.
Old 06-16-2013, 08:09 AM
mickmate's Avatar
This one?
Oil Cooler Shroud Oil Cooler Shroud [427] - $162.00 : Acton Custom Enterprises, Custom Metal for Cobras
mickmate
http://www.actoncustom.com/
Old 06-17-2013, 09:17 AM
Thanks for that guys.
So my question is:
is there any metalwork to the side of the shroud, directly under the radiator itself? It looks to me on some of the pics that there is some ali sheet that goes directly under the rad, pop rivitted presumable to some lower piece of frame under the radiator.
kevin
Old 06-17-2013, 10:32 AM
Dominik's Avatar
The front part of the shroud sits on top of the oil cooler, directing air in seperatetely from the radiator. The rear is mounted to the bottom of the radiator.
The big holes in Nick's pic are for the oil lines. The duct needs to be trimmed to fit to your body shape on the sides. As does the radiator shround to force all air through the radiator.
It it was any harder to explain I would add a pic... (which I don't have)
In essence: The radiator gets cold air and the oil cooler gets cold air. Either air flow won't interfere with each unit, nor can it escape to the sides or bottom.
Old 06-17-2013, 10:36 AM
mickmate's Avatar
Hi Kevin, yes there is a panel either side. It is a rectangular shape with an S shaped bottom edge to match the body shape where the oil cooler bulge is.
mickmate
Old 06-19-2013, 11:22 AM
thanks Mick - thats what I wanted to know!
do you have any pics of that area? have done a lot of web searching without any joy.
Old 06-19-2013, 01:56 PM
mickmate's Avatar
I have some better pics but how's this to get started.
mickmate
Old 06-20-2013, 12:39 PM
thanks, any further detail like that would be great.
Old 07-02-2013, 06:43 PM
Default oil cooler fittings
anyone have the part number on the oil cooler hose and the hose fitting that connects to the 90 degree angle blue fitting
thanks for any help with this
Old 07-16-2013, 10:11 AM
Dominik's Avatar
For your hose and fitting any speed shop should be able to assist (Russel, Earls).
Morris likes this.
Old 08-17-2013, 06:06 AM
Hi Kevin this reply may be a little late but if its any help I have a car you can measure. I live in the Leicester area. It may be of use for you to take your own pictures.
Cheers Redcar
Old 08-17-2013, 03:48 PM
FatBoy's Avatar
Hi Redcar,
What Cobra do you have? I'm not far away in Lutterworth.
Paul
Old 08-19-2013, 01:25 AM
Hi Paul. It's Gren!
Old 08-19-2013, 05:24 AM
FatBoy's Avatar
Aha, the penny drops.
