Like Tree8Likes
Old 12-20-2017, 10:35 AM
Too bad AK isn't close to CA, DanEC can tinker with my Cobra anytime.
In fact, grab some polish and the orbital buffer and have a good time re-polishing my aluminum.
Uhhh, that's AR, not AK. We need to get you an eye examination.
Old 12-20-2017, 10:58 AM
RodKnock's Avatar
Well, he might as well be in AK as far as I'm concerned.
My eyes are fine, but I have this pain in my a$$...
Old 12-20-2017, 11:02 AM
Well you should be dancing now that the new tax bill is going to be signed....
Old 12-20-2017, 11:14 AM
RodKnock's Avatar
Remember, I live in CA. So, it's not all good news. And then there's that whole $1.5 Trillion being added to the deficit.
Old 12-20-2017, 11:21 AM
DanEC's Avatar
What's that tune - Smoke gets in my eyes.
I think I have my next "tinkering" project for this winter - pull and re-seal my Toploader.
So far Patrick I don't think I need one of those oil/air separators on my ERA - no PVC system and no oil vapor issues. But I do run them on my Lightning PU and my former 12 GT Mustang and current GT350 Mustang. Collect a bunch oil in them in the Mustangs.
DRED likes this.
ERA 782 Running
Old 12-23-2017, 10:00 AM
wolf k's Avatar
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
A recent Mcclusky CSX 33-- restoration that is in our shop
LMH and DanEC like this.
Old 01-07-2018, 02:15 PM
ACHiPo's Avatar
Just saw CSX 3239 posted from Barrett-Jackson. Not sure if these are original, but they appear to be plastic, and definitely not Girling.
Old 01-07-2018, 04:43 PM
DanEC's Avatar
Evan - well that is interesting. Leaning towards just leaving mine well enough alone. I'm no more inaccurate in that detail than that obviously beautiful original (mostly original?).
What are you planning to go with on your ERA?
ERA 782 Running
Old 01-08-2018, 07:24 AM
ACHiPo's Avatar
Girlings. Until they leak, and then ???
Old 01-08-2018, 08:56 AM
bcrumpley's Avatar
Cobra Make, Engine: ERA #828
Since I'm a little way behind you Evan, I will be watching this. I sure like the idea of the Girlings, but hate the idea of brake fluid eating into the finishes of everything below them.
Bobby
Old 01-08-2018, 04:06 PM
DanEC's Avatar
Bobby
We can help with that a little (the "we" includes patrickt). The fluid cans have a nipple on the bottom with a compression fitting. They need to be taken apart and sealed with a brake resistant sealer when reassembled. Here is a thread patrickt started on this.
Brake Fluid Resistant Sealant for Girling Reservoirs
I believe I used a different sealer but as long as it's fuel/brake resistant it should work.
Next step is to buy brake cylinder cap gaskets for a closed system. Patrick wrote about this somewhere too but I couldn't locate it. Here is what you will need.
These will gasket the cap to prevent a leak and have the inner bellows that follows any drop in fluid level.
The 3rd step that ERAChase passed along was to double clamp the rubber hoses to the metal lines, orienting the two clamps 180 degrees apart. Here is a picture.
And 4th - don't fill the reservoirs much over about half full. They are small but significant fluid is also in the long lines down to the master cylinder. I've seen larger (longer) cans but ERA provided the standard smaller ones. I'm not sure what size was actually used on the S/C cars. I've seen pictures with the large cans for the brakes and the standard can for the clutch. And I've seen pictures with standard cans for all three. It's good practice to check the fluid level every few months. Mine have been on for about 5 years now and are leak free (knock on my head (wood)). Still, I often run a finger around the bottom and along the lines just to make sure they are staying that way.
AndrewB likes this.
ERA 782 Running
Old 01-08-2018, 04:44 PM
Girling Reservoirs have improved since I had mine put on (and since I sealed them up). These from Moss Motors are much better made than even the originals, much less the replicas: https://mossmotors.com/tank-assembly-single-supply
Here is a link to the instructions that come with the cans: https://mossmotors.com/media/instructions/582-976.pdf
  #33 (permalink)
Old 01-08-2018, 05:05 PM
DanEC's Avatar
Well heck - that takes all the work out of it. They have two part numbers BN1 and BN2 - I wonder if they are two different length cans?
ERA 782 Running
  #34 (permalink)
Old 01-08-2018, 05:40 PM
No, BN1 and BN2 were the two models of Austin Healey cars that used them.
  #35 (permalink)
Old 01-09-2018, 07:35 AM
bcrumpley's Avatar
OK then, looks like the ones from Moss are the way to go. Now to find the next thing for me to fret over...
  #36 (permalink)
Old 01-09-2018, 07:49 AM
DanEC's Avatar
Not sure what level of completion you are having ERA perform - but if you are doing some of the assembly you may still want to purchase the pre-bent lines kit from ERA. They will include a handy template for mounting the reservoirs on the wheel well aluminum.
ERA 782 Running
  #37 (permalink)
Old 01-09-2018, 08:11 AM
LMH's Avatar
LMH LMH is offline
I just received my reservoirs from Retro-UK. Very high quality! I could tell as soon as I unwrapped one. These are not converted glue cans. Weigh about twice as much as other reservoirs I’ve held. Pricey but as close to original as I could find.
Alba gu brąth
  #38 (permalink)
Old 01-09-2018, 08:49 AM
bcrumpley's Avatar
Thanks Dan, that's good info. It will be painted up there, but still on casters when I pick it up, so still plenty of assembly to do.
  #39 (permalink)
Old 01-09-2018, 11:14 AM
DanEC's Avatar
Larry - do you have a link to them or any photos?
ERA 782 Running
  #40 (permalink)
Old 01-09-2018, 11:38 AM
LMH's Avatar
LMH LMH is offline
Retro-uk - Misc parts
I wish the bottom fitting was mounted off-center as originals were but I’ll make it do.
Alba gu brąth
