Go Back   Club Cobra > For Sale > Parts Wanted
Old 09-23-2006, 07:05 PM
Cobra Make, Engine: Kirkham, Pond Aluminum 482FE
Default WTB Holley 750cfm HP 80528
Want to buy a Holley 750 cfm HP race carb with vac. secondaries. Holley part no. 80529. They're on eBay for under $400, so I'm looking for a bargain. This is for an experiment...
edit: 80528 with mechanical secondaries, please.
Old 09-23-2006, 11:05 PM
xlr8or's Avatar
Joe your car is too light for a vacuum secondary setup. Go with mechanicals if you can.
Old 09-24-2006, 05:21 PM
Originally Posted by HotRodJoe
Want to buy a Holley 750 cfm HP race carb with vac. secondaries. This is for an experiment...
What's the experiment ?
Old 09-24-2006, 05:33 PM
ZOERA-SC7XX's Avatar
Check with Jegs or Summint online...
Old 09-24-2006, 07:04 PM
ENTDOC's Avatar
got mine on EBAY
Old 09-24-2006, 07:13 PM
1badmofo's Avatar
Cobra Make, Engine: Hurricane 1022-BOWTIE
Joe,
Go with the mech sec.
Did the car run any better after we reset the timing?
Sid
Old 09-24-2006, 07:50 PM
dblbarrel's Avatar
Cobra Make, Engine: SPF2089
With only 450 hp the rear wheels on the dyno, I can understand changing the carb.
dblbarrel
Old 09-25-2006, 09:18 AM
Sid - it is a little smoother with less "kick", so I think that solved one problem, but I'm still rich most of the time and it acts like my plugs are needing replacement already. Thanks for the help!
Sid / Scott - mechanical secondaries it is!
Dblbarrel - horsepower isn't the problem...
Old 09-25-2006, 09:45 AM
1badmofo's Avatar
Joe,
Here is the MSD # from Jegs (121-8984) $93.00, lock your timing install this so it will start and it will idle cleaner and also make it feel better on the low end.
Sid
