-   Registration Forum (http://www.clubcobra.com/forums/registration-forum/)
-   -   429/460 VIN Numbers (http://www.clubcobra.com/forums/registration-forum/75860-429-460-vin-numbers.html)
mjmacqua 01-11-2007 06:47 PM
429/460 VIN Numbers
Can anyone help me quickly locate the Vin number from the engine.
mrmustang 01-11-2007 06:57 PM
If (IF!!) there is a VIN stamped into this particular engine it would be located on a small pad located on the rear of the block just below the head on the drivers side. Most likely you will not find a VIN as Ford did not always stamp one in this series of engines. Of course as a fall-back you can always use the engine block casting number located on the passenger side of the engine block and usually hidden by the starter motor.........
Bill S.
mjmacqua 01-11-2007 07:06 PM
Thanks I'll take a look...
