-   Scratch Builders Forum (http://www.clubcobra.com/forums/scratch-builders-forum/)
-   -   Hinges? (http://www.clubcobra.com/forums/scratch-builders-forum/108004-hinges.html)
thefordguy 12-07-2010 07:20 PM
Hinges?
1 Attachment(s)
I got this set of hinges. I guess there the same for the hood, doors and trunk. I got 6 of these but I cant seem to figure out how to use them as a hinge. Can any one help?
ccx1984 12-07-2010 07:28 PM
hinges
you have to weld the plate with the three holes to the end of the bent tube opposite the bushing end.
thefordguy 12-07-2010 08:01 PM
does anyone have a picture of one on the car that I can see?
mickmate 12-07-2010 08:24 PM
Do you have the tabs that go on the frame for the hinge pin to go through?
thefordguy 12-08-2010 05:50 AM
no, all that you see in the picture is what I have.
ccx1984 12-08-2010 09:27 AM
hinges
click on mickmates picture of the pedal box in the for sale section , look at the picture of the cars door hinges.
mickmate 12-08-2010 11:20 AM
I've got pictures of the assembly on a car I'll find for you. There are two tabs with holes in them welded to the frame it looks like you're missing. A 1/4" screw goes through the two tabs with the sleeved tube end of your hinge between them. The other end has two of the plates you picture. One is welded to the frame of the panel the other is welded to the end of the bent tube. They bolt together there so you can align the panel or shim the height.
thefordguy 12-08-2010 04:45 PM
I wasn't able to find the pic in your photos, what page is it on? Thanks
mickmate 12-08-2010 05:20 PM
http://www.clubcobra.com/photopost/s.../size/big/cat/
Go to the gallery tab at the top, put in a search for hinges, get yourself a cup of coffee and start scrolling through.
