21Likes
11-10-2011, 06:01 AM
Yes John, the chassis is stiffer than before. It increased by calculated 5000 lbs over 90x64 diagonal torsion test in SolidWorks Pro.
The body including the trunk lid, hood and doors totals 39 pounds.
DRB GT40 MK1 red #49- sold
SPF 2063
11-10-2011, 06:15 AM
Quick check about the windshield height.
The first part of the rollbar is fixed and has the same height as the windshield. The rollbar will be braced forward - thus it needs more work.
Tubular sub frame for the rear part of the body - later also base for the door lock.
Rear passenger side splash shield welded in place.
Inside view of it.
The driver side, as you can see I mostly work on two or more places at the same time. This is the final version of the dashboard.
Time to start on the sway bar.
Stay tuned. Soon I will fabricate the inner frames for the hood, trunk and doors. The door latches should come in any day.
SPF 2063
11-10-2011, 07:52 AM
tx
Since your quick jacks are functional, are you going to fabricate one of the original style quick jack lifts?
11-10-2011, 12:05 PM
I made this quick jack a few years ago - that is a 750 lbs bike which this one was effortless to move and secure.
The quick jack for the 289FIA will be longer and has wheels. 6 foot in total length and fold-able.
SPF 2063
11-11-2011, 06:18 AM
Pete:
45 degrees is a good place to start for an FIA windscreen...some guys have gone a bit lower than that - closer to 43 degrees... It makes the look of the car, IMHO.
- Allen.
11-14-2011, 06:29 AM
Yes Allen, 45 degrees that I had in mind too. The roll bar loop height was measured with the 45 deg. angle.
BTW: did you notice the dent near the passenger head light?
SPF 2063
11-14-2011, 06:45 AM
Ha..no I did not...my gaze usually stops at the sight of webers..
Considering that's CSX2345, I guess it's allowed to have a dent or two.
- Allen.
11-21-2011, 05:41 AM
Dash fabrication, I elected the drop-down style for the switches.
First test fit, the angle is perpendicular to the steering column/wheel.
These are the tabs which hold the dash board.
There are 8 mounting points for the dash.
Brake-fluid reservoir mounting bracket made from stainless steel.
Front showing. The Hydroboost is too close to the frame, the solution is to make the reservoir remote.
SPF 2063
11-21-2011, 05:53 AM
SPF 2063
11-21-2011, 06:02 AM
Harrison engine coolant overflow tank.
Bracket for the tank. The tank needs to be on the left side because of the later on plumping of the super-charger.
Right now I'm kicking the idea around of a small turkey pan with a square K&N filter on top.
This would eliminate under hood pressure created by the hood scoop. Besides that, it would deliver denser air to the system.
SPF 2063
11-25-2011, 06:41 AM
Thanksgiving is over back to work...
I hope everyone enjoyed the family and the food and for many the games.
SPF 2063
11-25-2011, 07:26 AM
SPF 2063
Reason: wrong picture
11-25-2011, 07:46 AM
SPF 2063
11-25-2011, 07:51 AM
Guys, it you have thoughts or any comment - please feel free and post. This thread turns slowly into a monologue...
SPF 2063
11-25-2011, 08:03 AM
TR
Cobra Make, Engine: scratch built 289 eclectic mix of fia/ussrc/early comp
don't worry, sometimes i feel the same when update my scratch builts thread.
i'm working on my #4 and thinking about windshield angle and i'll reduce 45deg to 43deg as you do.
regards
ozgur
11-25-2011, 06:39 PM
OR
I think the angle looks pretty good. Need to really get the car on the ground at it's resting stance, before you get too hung up on windshield angle.
ERA FIA 2088
11-25-2011, 06:47 PM
NC
Cobra Make, Engine: Factory 5 mk4 445 FE
N Freeking sane...
Keep up the good work. Your sir are amazing.
12-01-2011, 01:52 PM
tx
Since you asked...
Question on your fuel cell. Looks like the placement will keep it out of the main rear crumple zone (and that is good), but mounted that high, what will it do to your roll center? Can Solid Works model that?
Originally Posted by G-Pete
12-02-2011, 07:16 AM
John, the roll center is calculated based on your suspension setup.
Do you mean roll axis?
SPF 2063
12-02-2011, 08:00 AM
tx
Well, maybe I meant center of gravity.
I understand the roll axis to be the imaginary line connecting the roll centers at the front and the rear suspension points.
So maybe my question is, what impact is there on the suspension and handling by having the fuel tank higher or lower?
