backspace on CSX wheels
I am getting CSX 6079. I have noticed on several of the CSX cars the wheels are not right. I am sure that it is because of the dealers don't have the correct offset. There is very little room on the rears. to get the correct stance you need the correct offset on the wheels. any advice?
CSX wheel back spacing is shown in this seller's website.
https://vintagewheelsus.com/index.ph...roducts_id=575 |
I've never seen any CSX models with the incorrect offset, unless they went with a wheel other than stock 15" wheels. When you say "too close" are you saying the fender is too close to the tire? Adjusting the ride height helps.
You can determine the offset using the known backspacing using this calculator. Backspace to Offset Calculator | GTSparkplugs |
| All times are GMT -7. The time now is 09:23 AM. |
