-   Shell Valley Companies (http://www.clubcobra.com/forums/shell-valley-companies/)
-   -   Wiring harness light switch knob (http://www.clubcobra.com/forums/shell-valley-companies/41672-wiring-harness-light-switch-knob.html)
red99z 05-21-2003 08:08 AM
Okay guys,
On the Wiring Harness' light switch.... How do you fit it on the Dashboard? Does the knob unscrew so you can slip the shaft threw the dash from behind and reattach the knob or is there some trick to it? I don't want to force anything and brake it. Please advise.
Thanks
red99z
hog 05-24-2003 07:59 PM
Red
There should be a small button on the switch itself that can be pushed. Once this is pushed the shaft should then slide out of the switch. With the button depressed rotate the knob until it releases. Sometimes it takes some fiddling to get it to let go.
Hog
red99z 05-25-2003 08:40 AM
Thanks Hog, I got it.
red99z
