-   Shell Valley Companies (http://www.clubcobra.com/forums/shell-valley-companies/)
-   -   undercoat-----sound control (http://www.clubcobra.com/forums/shell-valley-companies/46303-undercoat-sound-control.html)
ravedemon 10-14-2003 06:15 PM
i'm writing this b/c i was thinkin of installing a material under and on the inside of my car called http://www.quietcoat.com/ i believe that if i install this the overall sound of the motor will sound "beefier" other than rattly from the fiberglass...... also to keep the loud exhaust noise outside the car and to quiet it up a lil on the inside.....also to possibly keep the motor heat out of the cockpit (for summer time), and to help keep the heat in (in the winter) if any one used this or thought of useing it please contact me and steer me in the right direction, so it wouldn't be $500 down the drain...
thanks
Jason
Jack21 10-14-2003 07:01 PM
Jason,
Two areas you should consider sound control - heat control. First is footwells, trans tunnel, and passenger compartment. I used double sided aluminum padding from dash forward to firewall for sound/heat control (Summit - ~$40/roll. Need 1 roll) and single sided aluminum padding from dash rearward under seats, rear trans tunnel, and behind seats. (Local Trac/Pep Boys, ~$20/roll, need 2 rolls. Used for RV/Van insulation)
You want to ceramic coat (at least) your headers inside and outside to keep engine/exhaust heat down. (I can hold my hand 1" from header on running motor and not get burned.) (I can also touch sidepipe heatshield with engine running.)
For cabin heat, install a heater/defroster from engine coolant (like real cars) for passenger compartment heat, and windshield defrosting. Works just as well as real cars too.
ravedemon 10-14-2003 07:41 PM
quiet coat
thanks for the reply, but do u believe that quiet coat is worth a shot?????
