SUPPORT OUR SPONSOR
December 2025
Old 04-09-2010, 04:23 PM
Cobra Make, Engine: Kirkham #570 w Shelby FE
Default Home-brew penetrating oil
A buddy of mine emailed this to me, came from some friends of his that are restoring a B-25 that have tried it and said it worked really well on some corroded antenna mounts they were fighting with...
Penetrating Oils Compared
Machinist's Workshop magazine actually tested penetrates for break out
torque on rusted nuts. Significant results! They arranged a subjective test
of all the popular penetrates with the control being the torque required to
remove the nut from a "scientifically rusted" environment.
Penetrating oil ..... Average load
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ..............214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix... 53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission
fluid and acetone.
Note the "home brew" was better than any commercial product in this one
particular test. A local machinist group mixed up a batch and all now use it
with equally good results. Note also that "Liquid Wrench" is about as good
as "Kroil" for about 20% of the price.
Anyone ever heard of this? Thought I'd share it with ya'll. Since it involves using Acetone I'd keep it away from paint or plastic stuff.
Old 04-09-2010, 08:42 PM
DAVID GAGNARD's Avatar
I've used ATF and Marvel Mystery Oil for many years with good results.........
To me anyway,ATF just seems to get down in the threads better than most anything else.....I've used it to free up old siezed junkyard engines before teardown,if left overnight, it works even better.....
Most times, I just use what I have close by.........
David
DAVID GAGNARD
Old 04-11-2010, 05:07 AM
They didn't test what I've been using (forever): Zepreserve, AKA Skunk P*ss. Smells bad, works great.
Old 04-11-2010, 07:19 AM
Cobra Make, Engine: jbl
i've used something similiar for shotgun barrel cleaning. the acetone does real well on plastic wad fouling.
Ed's Red Bore Cleaner
1 part Dexron II, IIe or III ATF, GM Spec. D-20265 or later.
1 part Kerosene - deodorized, K1
1 part Aliphatic Mineral Spirits, Fed. Spec. TT-T-2981F, CAS
#64741-49-9, or may substitute "Stoddard Solvent", CAS #8052-41-3, or
equivalent, (aka "Varsol")
1 part Acetone, CAS #67-64-1.
(Optional up to 1 lb. of Lanolin, Anhydrous, USP per gallon, OK to
substitute Lanolin, Modified, Topical Lubricant, from the drug store)
Old 04-13-2010, 02:08 AM
Maurice Butler's Avatar
Cobra Make, Engine: Scratch build, with help
brake fluid - dot 3 or 4 works quite well - just keep it away from the paint - then clean it all off properly afterwards
Maurice
researching for scratch build
Old 04-13-2010, 07:44 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
I've used Kroil for years to remove copper and lead fouling from rifle barrels. Many old military rifle barrels look shot-out, but a over-night soak in Kroil can make them look new.
Bill Stradtner
Old 04-13-2010, 08:04 AM
kitcarbp's Avatar
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Thanks that is really useful. I am surprised to see how well the tried-and- true low cost Liquid wrench works. Do results vary based on what types of metals we are talking about here aluminum versus steel corrosion ?
"...some assembly required, ages 8 and up...... well that took longer than expected......
HTML code is On
