SUPPORT OUR SPONSOR
December 2025
Like Tree1Likes
  • 1 Post By xb-60
Old 08-15-2020, 11:36 PM
xb-60's Avatar
Default Sealing 6AN adaptor onto fuel filter
I'm certain I'm on the right track here, but there's a small chance I'm missing something.
Here's a picture of my Bosch fuel filter...
The thread on the adaptor is a parallel thread, and a steel washer is supplied. Surely there is no way this joint will be fluid (petrol!) tight?
I will ditch the washer and source an O-ring to use in its place.
Any alternate opinions?
Glen
Old 08-16-2020, 05:21 AM
1795's Avatar
Glen,
There are thread sealants that are petrol impervious that you can use as well.
Jim
Old 08-16-2020, 06:01 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
If the washers are "soft" steel then it will seal. Brake calipers use a similar method.
I would probably use a thread sealer to be sure and use the washers that came with it.
John
Old 08-16-2020, 06:14 AM
You're correct on the o-ring in the the AN815 union. A Buna (aka Nitrile) works best on Gasoline or Ethanol mix.
https://www.efunda.com/designstandar...one&SC=Ethanol
There are several companies the sell AN to ORB (o-ring boss) fittings that also include the oring with it.
https://vibrantperformance.com/catal...e75f2975267d6f
https://www.highflowfuel.com/c-12084...-male-orb.html
Old 08-17-2020, 01:51 AM
xb-60's Avatar
Thanks for the comments, friends!
I am going with the Nitrile O-rings. I don't want to have to re-address this later
Glen
Old 08-17-2020, 01:26 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
It looks to me like you don't have the right type of fittings. Are you sure the fittings on the Bosch filter aren't NPT? I suspect you need AN on one end and NPT on the other. That's not what you have now.
Chris
Old 08-17-2020, 07:30 PM
xb-60's Avatar
It's a 6AN thread on one end of the adaptor, and M14x1.5 (definitely not a tapered NPT thread) on the other end.
The thread on the Bosch filter is a matching female parallel M14x1.5 thread.
Hence my concern that the adaptors won't seal without (Nitrile) O-rings.
The two adaptors (ie one for each end of the filter) are identical, and the threads on both ends of the filter are identical.
Old 08-17-2020, 08:01 PM
Gaz64's Avatar
Glen,
Can you show a photo of the fitting screwed right in, to where the washer should function like any other type of sealing washer, like a sump plug?
If you can get an "ORB" fitting, then an O-ring of the right section could be used. I have done this on regulators etc.
Gary
Gary
Old 08-17-2020, 09:50 PM
xb-60's Avatar
Hi Gary,
Are you saying that the steel washer would/could seal adequately?
Glen
Old 08-17-2020, 10:58 PM
Gaz64's Avatar
I would use an aluminium or soft copper washer.
Gary
Old 08-17-2020, 11:59 PM
xb-60's Avatar
Does the adaptor that I'm using (see pic.) look like an ORB fitting? I'm not familiar with them; I've only ever used or specified (professionally) O-rings with correctly designed and toleranced O-ring grooves.
Old 08-18-2020, 03:39 AM
Gaz64's Avatar
I would say that fitting is meant for a flat washer.
The taper just below the hex helps to self centre the washer.
An ORB fitting doesn't have that taper, which gives the gap for an O-ring to fill into.
You could machine that taper out, then select a Viton or Buna O-ring of the correct section thickness.
Gary
Old 08-18-2020, 10:38 AM
Cobra Make, Engine: Kirkham #259
Use https://www.pegasusautoracing.com/pr...yABEgKkRvD_BwE
These are the best way to seal a fuel filter
Morris
Old 08-18-2020, 05:08 PM
Gaz64's Avatar
Yes, another option. Thanks Morris.
Gary
Old 08-19-2020, 01:59 AM
xb-60's Avatar
Thanks Morris. I'll use the Stat-o-Seal washers as a backup if the following doesn't work.
I've fitted Cu crush washers both ends of the filter; added fuel for a static test on both ends and it's looking good.
Name:  20200819_Bosch_fuel_filter_with Cu_washers.jpg
Thanks all for suggestions.
Glen
1795 likes this.
HTML code is On
